In 8.03.409c (and I expect higher), you can use a summary query to do this...you check the box to summarize the table in version 8 - I am not sure if there is something similar in version 9...For example, I have a BAQ that sums labor hours per Employee...EmpBasic is not checked, LaborDtl is checked...Calculated field for hours is TOTAL(LaborDtl.LaborHrs). Of course, yours would use the JobOper table?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bildo564
Sent: Monday, March 11, 2013 7:58 PM
Subject: [Vantage] Needed BAQ Help: 905.701
Need to get earned labor hours from job receipts to inventory. Our methods are sometimes as much as 4 operations and each have a production standard of pieces/hour. When trying to write a BAQ, we get four lines for each part number, relates to how many operations we have on the job. Is there a way to only get one line per job receipt and have labor hours for each operation summed-up?
Billy
Billy
