Nesting Software Integration
Is anyone integrating nesting software with E10 to the point where actual run times per part are being reported? We are trying to get more accurate with our production times per part, and have to invest in nesting software upgrades. Not sure if one package stands out in terms of being compatible or easy to integrate with E10.
In general, without actual run data present; what would be the best way to set up a part to get the most accurate costing labor and production time when you have a nest with one large part and a group of smaller ones varying in size. We often see that the first part get all the production time, and the remaining parts 0. The first part cut is not always the largest part.
Thanks!
Paul
