Excellent! Glad to hear it!
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
*John Driggers*
*:: 904.404.9233
:: waffqle@...
On Thu, Sep 20, 2012 at 10:35 AM, Mike Abell <mabell@...> wrote:
> John,
> I truly appreciate your help. Worked like a charm.....
> Mike Abell
> Systems Analyst / Network Administrator
> Flexial - BOA Group - Cookeville, Tennessee
> Office: 931.432.1853 ext 302
> Mobile: 615.418.3055
> email: MAbell@...
> -----Original Message-----
> Of John Driggers
> Sent: Thursday, September 20, 2012 9:24 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Newbie to BPM, need some help on altering Part
> Master
> The catch is on your condition:
> -The ttpart.ClassId of the update row is equal to ""
> Epicor differentiates between 'Updated' and 'Added' rows. Add another
> condition that is the same, EXCEPT change it to say 'the added row'. Make
> sure you use an 'OR' instead of an 'AND' between the conditions so that it
> fires whenever either of them hits.
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> On Thu, Sep 20, 2012 at 10:16 AM, Mike Abell <mabell@...> wrote:
> > Thanks John...I got this to work but only if I am "updating" a part.
> > If I enter a "new" part, it still allows me to "save" it first but on
> > subsequent edits, it will fire and make me enter the ClassID as I
> > want. How do I get it to work to make it "mandatory" that a Class is
> > entered when entering a part from scratch. Here is my current BPM:
> > Table: ttPart
> > Pre-Processing Condition: The ttpart.ClassId of the update row is
> > equal to ""
> > Pre-Processing Action: Raise exception based on the ClassID issue
> template.
> > As stated, it works correctly but only if I'm "updating" a part
> > already in the system. It doesn't fire when creating a new part from
> > scratch..I need both conditions covered. Thanks for your help!
> > Mike Abell
> > Systems Analyst / Network Administrator Flexial - BOA Group -
> > email: MAbell@...
> > Behalf Of John Driggers
> > Sent: Wednesday, September 19, 2012 8:51 AM
> > Master
> > You should be able to do this pretty easily without even writing any
> code.
> > You'll need to create a pre-processing directive on the Part.Update
> method.
> > Set the condition to:
> > -Value of the Part.ClassID field is ""
> > And set the action to:
> > -Raise exception based on the designed template.
> > That should do the trick.
> > *John Driggers*
> > that?*
> > *:: 904.404.9233
> > :: waffqle@...
> > On Wed, Sep 19, 2012 at 9:44 AM, Mike Abell <mabell@...> wrote:
> > > I am very new to Vantage 8.03 but I do have some development skills.
> > > I haven't had any formal training on BPM's but I can see they can be
> > > very powerful judging by the number of posts about them on the
> > > Vantage usergroup. I have a need to alter the "Part Master" entry
> > > screen to add a rule that says that the "Class" field cannot be
> > > blank and must have something entered in order to submit a new part.
> > > I think this might be a simple BPM but since I've never done one, I
> > > thought I'd ask for some help on this first one to get my feet wet.
> > > Can anyone give me some guidance on what this would require and any
> > > repercussions that might occur due to the change. Thanks so much!
> > > Mike Abell
> > > email: MAbell@...
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
