No servers available - Any ideas other than licensing?
I believe this is an app server issue. they're all busy. check you app servers and ensure they are not being used by other periodic processes (mrp is a big culprit) - worst case - increase the number of app servers
---In vantage@yahoogroups.com, <jsmith@...> wrote:
Another thing...I know it's basic but depending on how many you have in IT.  Could be that your antivirus is scanning your Epicor Drive or you backup software is backing you Epicor Drive.
--- In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:
Yeah, absolutely… I don’t believe this error has anything to do with licensing.  You have no more appservers available; they’re all busy.  I’ve personally (unintentionally) created this scenario with:
1)      Process MRP:  Too many MRP/Schedulers running
2)      Bad BAQs
3)      ODBC use (big queries or other rogue activity like updating)
4)      A coincidental combination of other hefty system reports being run simultaneously
5)      Table/record locking (due to system, BAQ, ODBC)
Do you see any log file errors?  Look in System Monitor during the times you experience that error and see if you notice anything odd that was being run.
You can increase/add appservers in PET.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karen Schoenung
Sent: Thursday, September 19, 2013 7:39 AM
To: vantage@yahoogroups.com; Wendy McInnis
Subject: [Vantage] No servers available - Any ideas other than licensing?
Good morning,
For the past couple of days We are receiving no servers available errors  more often than in the past.  Does anyone have a suggestion what else we can look at?  Epicor admin tools indicate we have free licenses so licensing does not seem to be the problem.
Thanks in advance,
Karen
Connected by DROID on Verizon Wireless
#ygrps-yiv-131317949 {word-wrap:break-word;background-color:#ffffff;}
Good morning,
Thanks in advance,
Karen
1)      Process MRP:Â Too many MRP/Schedulers running
2)      Bad BAQs
You can increase/add appservers in PET.Â
Good morning,
Thanks in advance,
Karen
What version are you on, Karen?
We are on 607a, and have had this issue on and off since May.  Had support engaged since then, Including Ben Nixon.  Doesn't seem to be any 1 thing that causes it.  What we have noticed is it is a combination of processes running at the same time.  User File access is a big part of it, as Epicor has it tied to the PatchFld table.  Then we have noticed that Journal tracker, RMA processing, Invoicing, and other processes contribute to it.   It brings our system to a crawl for about 30 minutes each time it happens.  We are in the process of testing the 702A upgrade to eliminate this.
--Matt Caldwell
--- In vantage@yahoogroups.com, <kschoenung@...> wrote:
#ygrps-yiv-1891936799 #ygrps-yiv-1891936799ygrps-yiv-317719828 body {word-wrap:break-word;background-color:#ffffff;}
Good morning,
Thanks in advance,
Karen
As mentioned above, there are several things that could cause this.  If it's a new situation, I'd look strongly at possibly the bad BAQ option.  If you have a new dashboard or process that you've just started running, it could be causing app server threads to run out of control.
If you take a look at Epicor's performance tuning documentation, I think they recommend one app server instance for every three Epicor users.  You can configure the Initial, Minimum, and Maximum setting for how many app server instances you want to have start on the Epicor905 app server.  The Maximum is what you are bumping against.  If you're just experiencing activity growth, increasing that Maximum number should resolve your problem.  If you have a broken or runaway process, increasing the number will just buy you a little time until it happens again.
I'm tempted to say that the default Maximum value is 20 which, by their suggestion, should handle about 60 users.  Epicor will start up the Initial number of app server instances and then spin more up or down based on the Minimum and Maximum values as needed.  There has been some discussion that setting all three values to the same (the Maximum value) will offer better performance at the cost of always consuming memory on the server even if it isn't "needed".
One other possibility could be that you have not yet hit the Maximum number of app server instances, but the server does not have enough available memory to spawn a new instance.
--Matt Caldwell
#ygrps-yiv-458165045 #ygrps-yiv-458165045ygrps-yiv-123285269 #ygrps-yiv-458165045ygrps-yiv-123285269ygrps-yiv-317719828 body {word-wrap:break-word;background-color:#ffffff;}
Good morning,
Thanks in advance,
Karen
 Are you on SQL Karen?
#ygrps-yiv-90325523 #ygrps-yiv-90325523ygrps-yiv-1862109260 body {word-wrap:break-word;background-color:#ffffff;}
Good morning,
Thanks in advance,
Karen
#ygrps-yiv-2092536412 {word-wrap:break-word;background-color:#ffffff;}
Yes
-----Original message-----
To:
"vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent:
Thu, Sep 19, 2013 14:44:02 GMT+00:00
Subject:
[Vantage] RE: No servers available - Any ideas other than licensing?
Good morning,
Thanks in advance,
Karen
#ygrps-yiv-1061974548 {word-wrap:break-word;background-color:#ffffff;}
Vantage 803409c sql
To:
Sent:
Thu, Sep 19, 2013 13:56:57 GMT+00:00
Subject:
--Matt Caldwell
Good morning,
Thanks in advance,
Karen
Well, this is strange.  I'm not sure I've seen this before and I have been following this thread this morning.  What, did Karen send out some juju here?  All of a sudden I had two users get the same error. I got in to Vantage without any problem and it was fairly speedy (I guess as speedy goes in Vantage) , so I had them close out and reopen Vantage. Came back fine and they are happily working again.
I would still like to see if someone does come up with something a little more definite.  But since like I said, it doesn't happen often (oh, why did I sat that??), I wasn't super concerned.  We're on 8.03.405.
Kurt
Kurt
#ygrps-yiv-1445737500 #ygrps-yiv-1445737500ygrps-yiv-1512447357 body {word-wrap:break-word;background-color:#ffffff;}
Vantage 803409c sql
To:
Sent:
Subject:
--Matt Caldwell
Good morning,
Thanks in advance,
Karen
Ha!  No problem Karen! :)
I somehow think the users here just butt heads on a locked file or accessing something because they both got the error about the same time. I'm pretty happy with it being a very few and far between thing here (knock on wood and spray my juju repellant).  Just makes it a little tougher to track a cause that way.
Kurt
 Hello,  from my experience this error is caused by running out of app servers.  The app servers are dynamically created and released as needed.  So they can run out, and be available a short time later.
  Have you tried allocating more app servers to your database ?
If you are not familiar with that portion of setup, download the performance tuning guide.
Hope that helps.
I saw the same thing that you mentioned.  I have separatde many of our users to different appservers and I have limited out Epicor905PrintServer to 10.  Last week, MRP did not run because No Servers were available.  It was hitting the max of 10 appservers now.  Typically we run at 3 during the day with some spikes.  I saw the same message "No Servers Available" in the server broker log.  So I changed the max Appservers to 15 and have not had a problem since.
Check you max servers setting on your Main or PrintServer.  Check the broker log to see if it is trying to spool up more than you are allowing it to.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of phornerjr@...
Sent: Friday, September 20, 2013 9:05 AM
Subject: RE: RE: [Vantage] RE: No servers available - Any ideas other than licensing?
Hope that helps.
No, we have SQL, not replication….
Sorry for the juju Kurt – hope it is only minor.
I am working remotely today and things are quite for today (a couple this morning).  I know there was an issue we found about our SAN being maxed at times, not sure if the hardware team fixed that and then this went away or if they found something else?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Anstey
Sent: Thursday, September 19, 2013 2:37 PM
Subject: RE: [Vantage] RE: No servers available - Any ideas other than licensing?
Are you using replication and replicating large amounts of data?  If so when replication is deleting data from the replication table, that causes the ‘No Servers  available’ problem.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of kurt.baker@...
Sent: Thursday, September 19, 2013 4:25 PM
Subject: [Vantage] RE: No servers available - Any ideas other than licensing?
Kurt
Kurt
Vantage 803409c sql
To:
Sent:
Subject:
--Matt Caldwell
Good morning,
Thanks in advance,
Karen
Try decreasing the lease time for the App Servers. Also, check your available memory when the App Servers are maxed out, it's possible you're running at our memory which is causing the App Servers not to release properly.
--sf
> Hope that helps.
> Sorry for the juju Kurt â€" hope it is only minor.
> From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of kurt.baker@<mailto:kurt.baker@>
> To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
> Kurt
> Kurt
> --- In vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>, <kschoenung@<mailto:kschoenung@>> wrote:
> Vantage 803409c sql
> From: "matt@<mailto:matt@>" <matt@<mailto:matt@>>
> To: "vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
> Sent: Thu, Sep 19, 2013 13:56:57 GMT+00:00
> --Matt Caldwell
> Good morning,
> Thanks in advance,
> Karen
2)      Bad BAQs
Good morning,
Thanks in advance,
Karen
