(no subject)
Patch 5.00.316 is now available.
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
Winnipeg, MB R3H 0C4
http://www.neon-products.com/
mailto:rnewell@...
This message is intended only for the use of the person(s) ("intended
recipient")
to whom it is addressed. It may contain information which is privileged and
confidential.
If you are not the intended recipient please contact the sender as soon as
possible.
Accordingly any dissemination, distribution, copying or other use of this
message or any
of its content by any person other than the Intended Recipient is strictly
prohibited. We
have taken every precaution to ensure that this message is virus free but
we can not be
responsible for any damage that may be caused by its content.
Sent: Friday, April 06, 2001 10:18 AM
Subject: [Vantage] Re: Convmap.cp
V5.00? Had you seen the following document yet?
Page: 1229MPS
Summary: RB, unable to open convmap with custom report links
AnswerBook: Vantage ChangeRequests
XA 5.00
Problem: Opening custom report links in Vantage generates error:
Resolution: Vantage 5.00 no longer uses the registry to connect to
report builder
1.) Open the report builder.vtg and edit the "other parameters" line
it should look like this, with reference to the proper mapped drive
and server:
[Vantage Startup]
Executable=V:\Progress\bin\prorb32.exe
Database=V:\Vantage\db\vantage
IniFile=V:\Vantage\Vantage.ini
ParameterFile=V:\Vantage\db\Vantage.pf
ConnectOptions=-N TCP -H mntech -S epic50
TempDirectory=C:\Vntg50
StartupProcedure=
OtherParameters=
Note: the 'OtherParameters=' line is blanked out
Apparently this causes no problem with the database engine because it
uses the registry so. You will also need to edit the
progress\Bin\progress.ini to reference the mapped drive path instead
of the physical drive path. The startup section should look something
like this:
[Startup]
V6Display=no
;ImmediateDisplay=yes
;MultitaskingInterval=100
DefaultFont=MS Sans Serif, size=8
DefaultFixedFont=Courier New, size=8
DLC=V:\progress
Use-3D-Size=Yes
PROBUILD=V:\progress\PROBUILD
PROPATH=.,V:\progress\gui,V:\progress,V:\progress\bin,V:\progress\PROB
UILD\EUCAPP\EUC.PL,V:\progress\PROBUILD\EUCAPP
UseSourceEditor=yes
EditorConfigPath=V:\prowork\proedit
Where V is a mapped drive.
Pay special attention to the DLC path, that it says V:\progress, NOT
V:\epic50\progress
XA 5.00
Denise Brown
--- In vantage@y..., Steven Beals <sbeals@b...> wrote:
> We are getting this error, Unable to open convmap.cp, anytime
someone
> tries to run a custom report in vantage. I have uninstalled and
> reinstalled progress client, but am still getting this error.
Anyone
> have a fix for this.
> Thanks
> Steven Beals, CCA
> IT Manager
> Beaver Brook Circuits, Inc.
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
We are getting this error, Unable to open convmap.cp, anytime someone
reinstalled progress client, but am still getting this error. Anyone
Steven Beals, CCA
IT Manager
Page: 1229MPS
XA 5.00
report builder
and server:
[Vantage Startup]
StartupProcedure=
OtherParameters=
like this:
[Startup]
V6Display=no
DLC=V:\progress
Use-3D-Size=Yes
UseSourceEditor=yes
V:\epic50\progress
XA 5.00
Denise Brown
someone
Anyone
> Thanks
> Steven Beals, CCA
> IT Manager
