Hello group,
Heres what fixed the "Unable to open convmap" error for me. Tech support
sent me the same info that Britt posted. This fix bothered me because I
have 30+ workstations that work just fine, why should I go mucking around on
the server, potentially causing a network wide problem. Bart and Troy's
suggestion made more sense. On the workstation I tried to uninstall progress
9.1c but got an error so I manually cleaned up the regestry removing all old
references to progress. I then reinstalled the progress client from the
server using progress\netsetup\setup.exe like Bart and Troy suggested.
Problem solved. Total time about 15 minutes, mostly spent deleting entries
in the regestry.
Thanks for the help.
Mark
Sent: Tuesday, July 30, 2002 2:57 PM
Subject: RE: [Vantage] convmap.cp
Thanks for the response everyone, I will let you know how this turns out.
Mark
Sent: Tuesday, July 30, 2002 12:11 PM
Subject: Re: [Vantage] convmap.cp
We had a similar problem, and here is what epicor sent us to fix it:
Summary: RB, unable to open convmap with custom report links
Book: Support Solutions
Page: 1229MPS
XA 5.00
Problem: Opening custom report links in Vantage generates error: unable
to
open convmap
Resolution: Vantage 5.00 no longer uses the registry to connect to
report
builder
1.) Open the report builder.vtg and edit the "other parameters" line it
should look like this, with reference to the proper mapped drive and
server:
[Vantage Startup]
Executable=V:\Progress\bin\prorb32.exe
Database=V:\Vantage\db\vantage
IniFile=V:\Vantage\Vantage.ini
ParameterFile=V:\Vantage\db\Vantage.pf
ConnectOptions=-N TCP -H mntech -S epic50
TempDirectory=C:\Vntg50
StartupProcedure=
OtherParameters=
Note: the 'OtherParameters=' line is blanked out
Apparently this causes no problem with the database engine because it
uses
the registry so. You will also need to edit the
progress\Bin\progress.ini
to reference the mapped drive path instead of the physical drive path.
The
startup section should look something like this:
[Startup]
V6Display=no
;ImmediateDisplay=yes
;MultitaskingInterval=100
DefaultFont=MS Sans Serif, size=8
DefaultFixedFont=Courier New, size=8
DLC=V:\progress
Use-3D-Size=Yes
PROBUILD=V:\progress\PROBUILD
PROPATH=.,V:\progress\gui,V:\progress,V:\progress\bin,V:\progress\PROBUILD\E
UCAPP\EUC.PL,V:\progress\PROBUILD\EUCAPP
UseSourceEditor=yes
EditorConfigPath=V:\prowork\proedit
Where V is a mapped drive.
Pay special attention to the DLC path, that it says V:\progress, NOT
V:\epic50\progress
XA 5.00
Britt Moelling
M&M Manufacturing
Mark Dupuis wrote:
Britt Moelling
M&M Manufacturing Co.
in the regestry.
Mark
Mark
Page: 1229MPS
XA 5.00
to
open convmap
report
builder
server:
[Vantage Startup]
StartupProcedure=
OtherParameters=
uses
The
[Startup]
V6Display=no
DLC=V:\progress
Use-3D-Size=Yes
UseSourceEditor=yes
V:\epic50\progress
XA 5.00
Britt Moelling
M&M Manufacturing
Mark Dupuis wrote:
> Hello group,ADVERTISEMENT
> Has anyone ever come across his error when opening a RB report
> in vantage:
> "Unable to open convmap file 'd:\epic51\progress\convmap.cp'". I have
> one
> workstation that can no longer open any of our custom reports. Our
> database
> is on a mapped V: drive. This machine is looking for D: (which
> happens to
> be the server drive with the share for the mapped V: drive.
> I tried the obvious remapping the drive, logging on as another
> user,
> rebooting but still get the error. These reports run fine on other
> machines. Me thinks I need to reinstall the Vantage client. Any
> other
> suggestions?
> Mark
> Yahoo! Groups Sponsor
> have already linked your email address to a yahoo id to enable access.
> and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Britt Moelling
