Hi all,
Is there any way to add notes/instructions to the dashboards for the users to read before running it?
Make sure the dashboard has a tracker pane, deploy it then customize it and add an epitext field where you will put the instructions
Addition to this.
Your customisations made to trackers will not be transferred when you migrate to Kinetic. You will be required to complete it again.
