I'm having the problem within Crystal and have not been able to resolve
it using the method below.
For some reason fields with a type of Memo are not available for Crystal
formulas or Sql expressions.
Rob
Of Olson, Brian
Sent: Monday, March 19, 2007 10:37 AM
Subject: RE: [Vantage] ODBC Error- Exceeding its max length -Vantage 6.1
Merant Driver
Thanks.......Any ideas about crystal reports?
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of Mark Wonsil
Sent: Friday, March 16, 2007 3:25 PM
Merant Driver
function:
SELECT SUBSTR(PartDescription, 1, 100) shortPartDesc
FROM PUB.Part
This is work if you're using a pass-thru query and I would imagine if
you want
the whole description, you can pull it down in pieces:
SELECT SUBSTR(PartDescription, 1, 100) PartDesc1,
SUBSTR(PartDescription, 101, 100) PartDesc2
FROM PUB.Part
Mark W.
Rob
Of Olson, Brian
Merant Driver
Merant Driver
> We are having trouble with the part desctiption being too large andthe
> merant driver is giving us the following error ODBC error Datadirect -In your SQL statement, limit the size of the field by using the SUBSTR
> Technologies Part Description in table """ has value exceeding its max
> length or precision.
> Has anyone got a solution....thanks
function:
FROM PUB.Part
you want
FROM PUB.Part
Mark W.
