There's a little book I bought at Borders called Microsoft Exchange
Administrator's Pocket Consultant that has helped me sift through all of
those screens and find the places to turn off the archiving and so on.
Lydia
hiattmfg@...]
Sent: Thursday, October 26, 2000 8:58 AM
To: Vantage Egroups
Subject: [Vantage] RE: off topic MS exchange help
http://www.swinc.com/resource/exch_faq.htm
Here's a link to a few Exchange tips. This guy suggests that PST files are
bad, and so is backing up the mailboxes at the Brick Level, like ARCserve
does. He suggests using alternate methods that are more stable.
As a side note, my IN & OUT directories are empty. Must be because I have
autoarchive turned off.
John Mueske
Hiatt Manufactuirng, Inc.
Message: 24
Date: Thu, 26 Oct 2000 08:27:45 -0700
jsolobay@...>
Subject: RE: off topic MS exchange help
Dan,
I set up an archive.pst in each users' home directory. To redirect the
archiving to this location you have to go to each client and in outlook
"Tools" - "Options" there is an auto archive tab that lets you set location
(It will also show you were the info is going, I think the default is on the
C: drive of the local machine. With my heavier users I also load the
archive.pst in their outlook directory so they can have quick access to old
info (makes them happy to see it there even though they don't use it much).
Hope this helps
Jerry L. Solobay
Ebco Aerospace
dans@...]
Sent: Thursday, October 26, 2000 5:49 AM
To: '
vantage@egroups.com'
Subject: [Vantage] off topic MS exchange help
We are running Small Business Server 4.5 and Outlook 2000 loaded
with all
the default settings. As such all e-mail is stored on the server.
The
systems is archiving e-mail in 2 folders
\exchsrvr\imcdata\in\archive and
\exchsrvr\imcdata\out\archive. I am looking for advice to manage
these
files. It appears that deleting e-mail and archiving at the client
level has
no impact on these files is this correct? I noticed a change in the
mailbox
resource totals but not in the archive files. Where is the path for
these
files called out in the configuration parameters? Should I be
setting
mailbox size limits? Should I reconfigure clients to store e-mail
locally
(reduced server transactions)?ghtly backups)? My search of MS
knowledge base
and Boarders book shelf came up short any help would be greatly
appreciated.
Dan Shallbetter
States Electric Mfg.
please go to the following link:
http://www.egroups.com/files/vantage/
