Off Topic
After checking at www.staroffice.com <http://www.staroffice.com/> I
couldn't find anything relevant to running StarOffice on Windows XP. I did,
however, find a post where a user said that he solved some issues by using
the Program Compatibility features and telling the OS that StarOffice needs
to see NT 4 SP 5.
Hope that helps,
Ted Kitch
Misha1, LTD.
866-464-7421
Sent: Friday, February 01, 2002 10:09 AM
To: 'Vantage@...'
Subject: [Vantage] Off Topic
Has anyone been able to get Star Office 5.2 to run with Windows XP without
giving the user Administrator rights?
Dave Cole
Reeder & Kline
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=218512.1856015.3360178.1269402/D=egroupweb/S=17050071
83:HM/A=928901/R=0/*http://ad.doubleclick.net/clk;3788034;6800959;v%3fhttp:/
/www.verisign.com/cgi-bin/go.cgi?a=b228473240057000>
<http://us.adserver.yahoo.com/l?M=218512.1856015.3360178.1269402/D=egroupmai
l/S=1705007183:HM/A=928901/rand=358381838>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Ted,
I just found the fix. You need to set the folder and all files in it to
full control for the user that is going to use it on that machine. That's
the only folder that needs to be changed. Also, when you install it, you
need to run the install using 'Run As' and run it as an Administrator.
Thanks for you effort,
Dave Cole
-----Original Message----From: Ted Kitch [mailto:onelist@...]
Sent: Friday, February 01, 2002 12:13 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Off Topic
<http://www.staroffice.com/> > I
to see NT 4 SP 5.
Hope that helps,
Ted Kitch
Misha1, LTD.
866-464-7421
To: 'Vantage@...'
Dave Cole
Reeder & Kline
ADVERTISEMENT
<http://ad.doubleclick.net/clk;3788034;6800959;v%3fhttp:/>
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Terms of Service.
ADVERTISEMENT
l/S=1705007183:HM/A=928901/rand=826348710>
Hi all,
I am looking at upgrading my Windows NT4 Primary Domain Controller to
windows 2000. Has anyone used the upgrade option with windows 2000 or
has everyone re-formatted and done a clean install? If you upgraded
did it go smooth? Anything I should watch out for?
Any input would be appreciated.
Ron Newell
Pattison Sign Group.
Ron,
We did a reformat and clean install. It went just fine.
Also, what brand of server are you running? If you purchased it with NT
then it is most likely old enough there may be some bios/rom/firmware
updates you need to do either before, during or after the Windows 2K
install. With our Compaq server, there were several of what Compaq calls
ROM Packs or Support Packs.
Dave Cole
Reeder & Kline
Sent: Monday, September 30, 2002 3:41 PM
Hi all,
Ron Newell
Ron,
I have found that it's best to do a clean install. If you have corrupted files currently then do just an upgrade then you may still have the corrupted files. The upgrade may not install or replace over them. If you do a format then a fresh, clean install then all your old corrupted files will be replaced.
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
Burton, Michigan
----- Original Message -----
Sent: Monday, September 30, 2002 4:40 PM
Hi all,
Ron Newell
I tried to upgrade twice from Windows NT to Windows 2000 on my PDC. Both
times it went really bad. I finally just formatted and started over. IT
was a pain but I knew I could get everything running that way. I now have
enough experience with Active Directory that I don't think it would be a
problem to upgrade.
Jeremy Leonard
IT Manager
K-T Corporation
Hi all,
Ron Newell
From past experience with both Windows and programming, I don't even upgrade
clients from one OS to another. The reason, things tend to slow down
significantly and problems tend to occur more often than if you were to
install a fresh copy over a low level formatted drive.
I like things clean on a system; reason: you know things will work.
Otherwise, you could someday spend hours trying to figure out why something
doesn't work or why you are receiving the infamous "Blue Screen of Death".
In a server's case, DEFINITELY would install a fresh copy and not even
attempt an upgrade.
I only perform upgrades if I am forced into it depending on the situation,
cause I like knowing exactly what's been and what's currently on my system,
I like control.
Just offering another personal opinion,
Jessee Holmes
Stremel Manufacturing Company
Hi all,
Ron Newell
Yup. I agree with the flush and fill idea. Seems to work the best and can
eliminate any problems you may have had with the old install.
Gary Wassing
MIS
SteelCraft Industries
519-271-4750
Sent: Tuesday, October 01, 2002 8:31 AM
problem to upgrade.
Jeremy Leonard
IT Manager
K-T Corporation
Hi all,
Ron Newell
Since he's trying to upgrade a PDC won't this require adding all the users
and security settings manually ?
Sent: Tuesday, October 01, 2002 9:24 AM
Gary Wassing
MIS
519-271-4750
problem to upgrade.
Jeremy Leonard
IT Manager
K-T Corporation
Hi all,
Ron Newell
A windows 2000 PC can not join a NT domain. It is my understanding, that if
you want to do a clean install you will have to create a new domain and
rebuild all of your user accounts and groups. If you do not want to do that
you have to upgrade the PDC first, which will convert your PDC to active
directory. Also the first active directory server is special you just can
not go back and format it latter after you add another server as an active
directory machine.
Subject: [Vantage] Off Topic [SMC WIRE FABRICATORS]
Hi all,
Ron Newell
I have approx. 25 PCs running Win2K on a NT domain.
I always disconnect all map drives prior to upgrading to Win2K. Maybe
that's the problem?
R Gors
Sent: Tuesday, October 01, 2002 9:36 AM
Subject: RE: [Vantage] Off Topic [SMC WIRE FABRICATORS]
if
that
directory machine.
Hi all,
Ron Newell
have
ADVERTISEMENT
I have been looking at Scott's reply for a full day trying to find a
polite way to respond. I am struggling, but I will try.
Any one who has read his response please ignore it. It is inaccurate on
all accounts. Everything that he says connot be done, can.
Windows 2000 (w2k) can join a NT domain. W2k server can be a part of a
NT domain. W2k can be installed without AD (Server and wkstn). You can
remove your fist W2k server from AD (it may not be easy - transfer FSMO
roles). Etc. etc.
Enough said. Now to answer Ron's question.
Upgrading and doing a clean install depends on your environment and what
you want to accomplish. Are you moving to AD? How many users? How
familiar are you with W2k & AD?
If you are just wanting to replace your PDC with a w2k server(as a PDC)
my advice is don't. If you are moving to w2k and AD then I strongly
suggest a clean install on a new (test) server, get to know w2k and AD.
Jim
Sent: Tuesday, October 01, 2002 8:36 AM
that if you want to do a clean install you will have to create a new
domain and rebuild all of your user accounts and groups. If you do not
want to do that you have to upgrade the PDC first, which will convert
your PDC to active directory. Also the first active directory server is
special you just can not go back and format it latter after you add
another server as an active directory machine.
Hi all,
has everyone re-formatted and done a clean install? If you upgraded did
Ron Newell
I think the easiest way to do a "clean" move to Active Directory (AD)
without losing your users and permissions is to grab a vacant workstation,
rebuild it as an NT 4.0 server, and promote it to the PDC of the network.
Then, upgrade that machine to AD. The rest of your servers will become part
of the AD. Then you can do "clean" installs without losing anything. After
putting W2K server on your old PDC, have it become part of the AD. Then
start transferring control from the temporary server to the new one (Master
Catalog, etc...). The temporary machine doesn't need to be much (even for
W2K server). We did this exact process successfully and used a PII 400 with
128 MB of RAM.
Chris
Christopher Gitzlaff
Manager - Information Systems & Technology
Major Industries, Inc.
Phone: 715-842-4616
Fax: 715-848-3336
Sent: Wednesday, October 02, 2002 8:05 AM
roles). Etc. etc.
Jim
Hi all,
Ron Newell
First I want to apologies for not being clear in my first post. When I said
that
a windows 2000 server can not join a NT domain I meant that it can not join
as a Active Directory Machine and simply was not clear in what I said.
The point I was trying to make, and if I an wrong I would LOVE to know how
to do this, was simply that you have to upgrade the PDC to Active Directory
to keep your accounts and groups intact and not have to create another
domain. You can not simply install W2k on a clean PC add Active Directory
and have it suck in the existing domain info.
Also I did not say you could not remove the first Active directory server
from an domain. I just said you can not SIMPLY FORMAT and then reinstall
W2k
Server on that machine, it does have special roles in the directory and,
as Jim noted, those roles need to me moved to another server before you
remove it from service.
Again I wish to apologies for my confusing presentation of what I was trying
to say. I wanted Ron to know it was a little more complicated then just
formating
and installing W2k. I hope that as a result of my last post all my future
posts will
not be summarily ignored. Please read them, then ignore them.
roles). Etc. etc.
Jim
Hi all,
Ron Newell
Thanks for everyone's input. I think I will look into the clean install
with this one.
Thanks again..
Ron Newell
IT Manager
Pattison Sign Group
1695 Sargent Ave.
Winnipeg, MB R3H 0C4
<http://www.neon-products.com/> http://www.pattisonsign.com/
<mailto:rnewell@...> mailto:rnewell@...
Sent: Wednesday, October 02, 2002 9:45
To: rnewell@...
said
that
join
how
Directory
Directory
server
reinstall
W2k
trying
formating
future
posts will
roles). Etc. etc.
Jim
Hi all,
Ron Newell
have
and
ADVERTISEMENT
<http://rd.yahoo.com/M=232673.2420628.3840241.2225243/D=egroupweb/S=1705
007183:HM/A=1194123/R=0/*http:/www.adinsdirect.com/>
<http://us.adserver.yahoo.com/l?M=232673.2420628.3840241.2225243/D=egrou
pmail/S=:HM/A=1194123/rand=523616960>
This information sent is intended only for the person or entity to which
it is addressed and may contain confidential and/or privileged material.
Any review, retransmission, dissemination or other use of, or talking of
any action in reliance upon, this information by persons or entities
other than the intended recipient is prohibited. If you received this in
error, please contact the sender and delete the material from any
storage devices.
This message was checked by Norton AntiVirus for all known Viruses .
Winnipeg Office.
This information sent is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or talking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any storage devices.
Winnipeg Office.
Does anyone know of a free utility for purging all Internet history and
files from PC's?
You mean aside from using the general tab in internet explorer properties?
You can set the history to zero (0) days and probably a simple batch routine
to delete *.* in the temporary internet files folder.
Terry L. Williams 176 Shadywood Circle Cranberry, PA 16319
ph/fax: 814-676-8650 tlw@... <mailto:tlw@...>
Sent: Wednesday, November 20, 2002 3:03 PM
files from PC's?
Not free ($24.95) but I am currently trying out Window Washer from Webroot.
Not only cleans cache, cookies, history, temp files but also meda player
files and other places IE puts stuff. There are plug-ins for various
applications to wipe their recently used file histories (So the boss doesn't
say; "What's this resume.doc in your Word file list?"). You can also
designate specific cookies to ignore. It has scheduling to run periodically
and/or at shutdown. Even has a bleach cycle to 10X overwrite files with
random bits for the truly paranoid. My main use (aside from space savings)
is to reduce stubborn cookies that can lead to targeted spam without turning
off or deleting all cookies.
-Todd C.
Sent: Wednesday, November 20, 2002 2:03 PM
files from PC's?
Good Morning Everyone!
My company is FINALLY upgradeing our servers, but with this upgrade
comes some software problems. We are currenly running a NT server
and a Novell server and we are going to 2 WIN 2000 servers. The
software problem is with our Faxserve.... The version we currently
have is for netware. So I need to either purchase the Faxserve for
WIN 2000 or come up with something else that is just as easy to
use....
My question to you is do any of you run a desktop faxing software? If
you do what is it and what do you think of it? ANY and ALL
recommendations are welcome
Thanks!
Could you not keep your Netware server up for just faxing?
Sent: Wednesday, April 30, 2003 8:41 AM
use....
Thanks!
