One requisition to multiple Purchase Orders
Hello,
I want to create multiple purchase order from requisition such that i can split quantities from a requisition line to multiple suppliers.
Is it possible in Epicor 10?
I understand you can attach suppliers in requisition but am thinking for a situation where the supplier is not yet known. By the time you want to issue PO for different reasons you might need to split quantities to multiple suppliers.
Regards.
I believe in during purchase suggestions you can split the qty and decide on suppliers too.
Also, you can easily hack this into being if needed.
You can make a PO from scratch that is not associated with a Req, and then tie them together after. We had to do that here as everyone was just starting to learn how Requisitions work.
In short, in PO Entry, I think in the Releases tab, go to the List tab (the grid) and you have to unhide the column for req and req line and then manually populate them.
It’s better to do it through the system, but this works if you have no other option.
