Open With Populating a UD Table Field (e9.05.606)
Hi All, we have created a custom form using a UD Table that tracks job quality issues. The form is accessed via an Open With menu from a dashboard that lists jobs with quality issues. The problem we have is that when you use the Open With from the dashboard to the custom form it does not populate the job number. The field used in the custom form is UD02.Key2. We have set the Context Menu field to JobHead.JobNum with no luck. Is it possible to perform and Open With to UD Table in e9?
