Good Day Jose:
Field help does not show a db file:field. That means it is a system
calculated ( or active) field, which means that the value is not 'read'
from a file, but computed on the fly.
Another example is 'Primary Supplier" if you check yes in Parts for
a Vendors screen, it does not write Y or N to the Vendor file, but
instead stores the Vendor Number in a Parts field.
There is no way to figure out its logic. You just have to know or
find it in some documentation.
Function help below might be of some help. My guess is that it
'reads' several pieces of information ( hold checkbox on order, A\R hold
settings, type of each, SO-line information, etc.) then either checks it
or not. An order can be on different types of hold for different SO
processes.
Best bet is call the Helpline, they are rather good at sending the
appropriate White-paper.
len.hartka@...
Of Jose Gomez
Sent: Friday, July 01, 2011 2:59 PM
To: Vantage
Subject: [Vantage] Order Credit Hold
In Customer Credit Manager under the Order's Tab there is a checkbox
called
Credit Hold which is allegedly bound to OrderHed. I can not for the life
of
me find this value on the Order Hed table. Anyone know where that is??
Its
realted the Customer Credit HOld but independent, that is the Customer
May
be on Credit Hold but the Order May not.,
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@... <mailto:jose%40josecgomez.com>
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez> <
http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez> <
http://www.twitter.com/joc85>
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
processes.
len.hartka@...
Of Jose Gomez
To: Vantage
called
of
Its
May
*Jose C Gomez*
*Software Engineer*
