[OT] Bar Codes
OK, Now you made my day. "Cultural Resistance" is an understatement here.
Changing the color of the Shipping Department's desktop, is enough to bring
things to a screeching halt... : ) Les
> -----Original Message-----
> From: Shirley Graver [SMTP:shirleyg@...]
> Sent: Monday, August 19, 2002 10:42 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] [OT] Bar Codes
> What I've done is looked at everything done in Zebra. I found that 80%
> were
> a standard format, so I created the standard format and will run samples
> for customer approval before we switch over. There's going to have to be
> some discipline added to the shipping department because they aren't going
> to be able to slop the data around like they've been able to do in the
> past.
> This won't be an instant transition and it won't be necessarily easy.
> "Cultural Resistance" is going to rear its ugly head. For those
> customers
> that require "Special" I'll have to do another RB format. I'm going to
> try
> and keep it to 2 buttons, one for the "Standard" and an elegant way for
> each
> customer to get their special.
> Shirley
> From: Les Tingley [mailto:ltingley@...]
> Sent: Monday, August 19, 2002 10:26 AM
> Hi Shirley,
> Are you recreating all of your Wasp Labels for the Zebra, or have you
> found
> a way to convert them into the correct format?
> Les
> > Sent: Monday, August 19, 2002 9:43 AM
> > We have Zebra's Z4M. We will be generating our barcodes out of
> Vantage.
> > We've commissioned some mild programing to allow a Report Builder
> Report
> > to
> > be run from a button click without any further user interaction. We
> are
> > converting over from Wasp Labeler. So far testing shows that this
> will
> > work
> > quite nicely. For those interested in the programing should contact
> Rick
> > Lane off list. I've already found a bunch of uses for Report builder
> > reports from a VB button. I'll also share my report builder report
> that
> I
> > use for generating the the AIAG lables. My plan is to have a button
> for
> > the
> > generic standard barcode and add buttons for those customers that want
> a
> > particular format. This would be done from the shipping detail VB.
> So
> > far
> > I'm able to pull what ever data I need with special fields for special
> > data
> > with some careful report building.
> > Shirley Graver
> > Systems Administrator
> > Rubber Associates Inc.
> > Cleveland/Akron, OH
> > From: lptingley [mailto:ltingley@...]
> > Sent: Monday, August 19, 2002 9:22 AM
> > Subject: [Vantage] [OT] Bar Codes
> > I recently purchased a Zebra 105Se, and now face the prospect of
> > having to recreate all our Customer barcode labels. The labels were
> > all created in software that comes with the Sato Lable printers.
> Most
> > of these labels require user prompts. I'm not an expert at
> barcoding,
> > and was hoping that somebody could tell me if it's possible to
> create
> > labels (with user prompts) that would be compatible with most label
> > printers? I wouldn't want to do this again, if we decide that we
> > didn't like the Zebras.
> > Thanks,
> > Les Tingley
> > MIS
> > Decorated Products
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> http://docs.yahoo.com/info/terms/
> ADVERTISEMENT
> have already linked your email address to a yahoo id to enable access. )
> and
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
all created in software that comes with the Sato Lable printers. Most
of these labels require user prompts. I'm not an expert at barcoding,
and was hoping that somebody could tell me if it's possible to create
Les Tingley
MIS
Decorated Products
We have Zebra's Z4M. We will be generating our barcodes out of Vantage.
We've commissioned some mild programing to allow a Report Builder Report to
be run from a button click without any further user interaction. We are
converting over from Wasp Labeler. So far testing shows that this will work
quite nicely. For those interested in the programing should contact Rick
reports from a VB button. I'll also share my report builder report that I
use for generating the the AIAG lables. My plan is to have a button for the
generic standard barcode and add buttons for those customers that want a
particular format. This would be done from the shipping detail VB. So far
I'm able to pull what ever data I need with special fields for special data
Shirley Graver
Cleveland/Akron, OH
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
Hi Shirley,
Are you recreating all of your Wasp Labels for the Zebra, or have you found
Les
> to
> work
> the
> far
> data
> Shirley Graver
> Cleveland/Akron, OH
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> ADVERTISEMENT
> and
We too are using the Z4M with Report Builder and it has been great (after a
few startup driver issues). A seperate RB for each customer's label format
so had to create a sub-menu just for labels. Selections (job, order,
etc...) made via regular filters and any that require non-system data are
also passed via filter (parsing the filter string). After the first few
"flavors" were made all the rest were similar to an existing one so new
formats only take about 20 minutes. I don't think it would be possible to
export something from WASP that would fit into RB but designing labels in RB
is pretty easy.
-Todd C
Sent: Monday, August 19, 2002 8:43 AM
Shirley Graver
Cleveland/Akron, OH
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.2225295.3666737.1829184/D=egroupweb/S=17050071
83:HM/A=763352/R=0/*http://www.classmates.com/index.tf?s=5085>
Thanks Todd,
RB really sounds like the way to go. I'm going to have to use VB fields like
Shirley, but that will be a one time shot. I'm just trying to avoid possibly
having to recreate them all again the future.
Les
> From: Todd Caughey [SMTP:caugheyt@...]
> Sent: Monday, August 19, 2002 10:36 AM
> To: 'vantage@yahoogroups.com'
> a
> format
> RB
> is pretty easy.
> -Todd C
> From: Shirley Graver [mailto:shirleyg@...]
> to
> work
> the
> far
> data
> Shirley Graver
> Cleveland/Akron, OH
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> ADVERTISEMENT
> and
> ADVERTISEMENT
> 71
> have
What I've done is looked at everything done in Zebra. I found that 80% were
to be able to slop the data around like they've been able to do in the past.
"Cultural Resistance" is going to rear its ugly head. For those customers
that require "Special" I'll have to do another RB format. I'm going to try
and keep it to 2 buttons, one for the "Standard" and an elegant way for each
Shirley
Hi Shirley,
found
Les
> to
> work
Rick
I
> the
> far
> data
> Shirley Graver
> Cleveland/Akron, OH
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> ADVERTISEMENT
> and
and
ADVERTISEMENT
