Thanks to everyone for the suggestions. I am just trying to cleanup and
protect things better than the current layout. Some of the maintenance
installations in the past resemble a cluster of 4 types of cable, a switch
and 3 hubs feeding our main production area. One slip up with a piece of
material or water and I'll digging through cable for weeks.
A few people mentioned wireless connections which we are exploring and I was
interested to is if anyone was using tablet PC's yet?
Thanks again,
Michael
Thanks again,
Michael
> -----Original Message-----
> From: Rich Shafer [mailto:rshafer@...]
> Sent: Thursday, August 28, 2003 3:03 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] [OT] Network Equipment Storage
> Michael,
> We had some used old large electrical boxes laying around.
> Drilled some holes.
> Installed a fan and filter.
> Gasketed the door.
> Sealed all other holes.
> Instant shop floor protection for electronics.
> Are they perfect? No, but the job they do is good enough.
> Most dirt is intercepted at the filter.
> Our shop environment can have metallic dust and grit, smoke and
> wind blown dust.
> No temperature control except, heat in winter 50 deg. F
> PC's inside have been running for 4 years just fine.
> Best of all they are really inexpensive.
> Rich
> From: Michael Benedict
> Sent: Thursday, August 28, 2003 12:54 PM
> Subject: [Vantage] [OT] Network Equipment Storage
> We are expanding into 2-3 other production areas that are not climate
> controlled and are looking for cabinets with fans and/or cooling for the
> hubs and switches. These are not rack mounted and will be
> located in the
> most central area to serve the clients. Can someone that has
> used these in
> the past recommend a good solution?
> Thanks in advance,
> Michael Benedict
> IS Manager
> Crestview Aerospace Corp.
> mbenedict@...
> must have already linked your email address to a yahoo id to
> enable access. )
> Builder and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
