test again like last summer
Sent: Tuesday, October 26, 2004 7:46 AM
Subject: RE: [Vantage] Vantage Upgrade Process
Correct, Switch it back (with your perameters instead of mine) and then set
up Progress Exp. and you should be good.
Jeremy
From: Moore, Jim (Anniston) [mailto:jmoore@...-ots.com]
Sent: Tuesday, October 26, 2004 10:43 AM
To: 'vantage@yahoogroups.com'
I'm about to do some test upgrades as well, Jeremy do you then just reverse
the ConnectOptions back to
ConnectOptions=-N TCP -H vantage -S 6000 -ld MFGSYS to put the db back in
multi user mode (live mode) or do you have to do
something else?
Sent: Tuesday, October 26, 2004 9:26 AM
Since you can use Progress 9.1D to upgrade from 5.1 to 6.1 you can use one
PC. Just install Vantage to different directories for each version. You
dont have to reinstall Progress at all. One thing I have found to make it
much easier is to replace
with
ConnectOptions=-1 -i -B 90000
This will start Vantage in single user mode. This way you do not have to
setup each database in Progress Expl. It also makes the conversions and
schema changes run much faster.
Just a thought,
Jeremy
Sent: Tuesday, October 26, 2004 10:07 AM
To: Vantage Groups (E-mail)
Subject: [Vantage] Vantage Upgrade Process
I am planning on upgrading from 5.2 to 6.1 and I want to see if this idea
might work.
Is it possible to have 2 computers, one with version 6.0 and one with
version 6.1 setup. Then take the 5.2 database and copy it over to the first
computer with version 6.0.
Run the schema change on our database.
Then take that database and copy over to the second computer with version
6.1 and run the schema change on it.
Will this idea work to get my database up to version 6.1 or do I need to go
through the normal process?
Any thoughts?
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Jeremy
something else?
with
Just a thought,
Jeremy
might work.
Any thoughts?
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
