When I worked in an aluminum plant (harsh environment) we went
through heads fairly often, however that seems a bit excessive. When
replacing the print head (at least in the S600 series) an Ohmeter is
required to set the base 'temperature'. I'm not sure if that applies
to the model you are using. We later gave up on the Zebra printers
and went to the SATO brand as the heads are made of ceramic. We ran
1 printer with 3 computers pumping out labels on it and only had a
belt wear out after 3 years. A new belt was 15.00 and the print head
was still in great shape.
--- In vantage@yahoogroups.com, "Marty Kuphall" <marty.kuphall@...>
wrote:
>Plus. Third
> I was just told we need yet another new print head in our Zebra 4M
> print head in the last 5 months at several hundred $$$ each.experiencing?
> What kind of print head life span are you Zebra printer users
>bar-coded and
> We print maybe 200 labels per day. Standard AIAG 4x6 labels with
> human readable data. Direct thermal process, not thermal transfer.All standard
> stuff. We also regularly clean the print head per Zebra'sinstructions.
>would like some
> I feel a print head should be lasting much longer than this but
> real life users to confirm this before I yell at our service vendorand/or
> Zebra.intended
> Marty Kuphall
> Chief Financial Officer
> Ultra Tool & Manufacturing, Inc.
> W169 N5954 Ridgewood Drive
> Menomonee Falls, WI 53051
> Phone: 262-703-0455
> Fax: 262-703-0468
> Toll Free: 800-779-3566
> marty.kuphall@...
> www.ultratoolmfg.com
> The information contained in this electronic message (email) and any
> attachment(s) to it is/are intended for the exclusive use of the
> addressee(s) and may contain information that is confidentialand/or privileged
> and exempt from disclosure under applicable law. If you are not theintended
> recipient(s) and have received this communication in error, pleasedo not
> distribute it. Instead, please notify Ultra Tool & Manufacturing,Inc. at
> 1-800-779-3566 or by email at general@... and destroy all copies of
> this message and any attachments. Thank you.
