Darren,
I used to have problems occasionally with printers - forms or paper getting
out of aliagnment. Watch the forms feed. Make sure they are lining up
straight and not at on angle. That the paper doesn't catch on the sides of
a box or tray where they are stacked. I have even had cables catch forms
and pull them off.
Sent: Wednesday, August 02, 2000 3:53 PM
To: vantage@egroups.com
Subject: RE: [Vantage] Packing Slip Printer?? Problems
I have looked at this as an option and even purchased a new printer that did
exactly the same thing out of the box. I know the noise is unexplainable at
this point, unless as Eunice outlined the line feed maybe getting scrambled
to the point the printer does not know what to do. The crazy thing is that
it picks itself back up on the next document and the problem occurs exactly
at the same point in the form - packing slip (right after the last detail
line and moves the page number to the middle of the form) - and never the
BOL. If it was a physical problem with the printer or a form travel problem
wouldn't you expect more random occurences of the problem??? Different
points in the page and different reports.
We are pulling the paper and do not place it in the box. The paper is
loosely stacked beneath the printer.
and pull them off.
