Carey,
I still don't know what happens if there is no job exists and stock
level for the "car" falls below minimum qty. Will it generate po
suggestion for the raw material?
--- In vantage@yahoogroups.com, "Carey S" <rotary1@...> wrote:
> Sorry for the confusion. I hit the button before I proofed...I
think faster
> than I type...
> If the PULL AS ASSEMBLY is not checked, it will look to pull in an
> already-made sub into the job. Therefore, if the sub is not
already "in
> stock" it should create the suggestion for it. If the box is
checked, it
> will try to build "car" for example, and pull in the components
for "engine"
> while it is trying to build the "car", and what we want to do is
literally
> pull the "engine" off of the shelf.
> Carey
> >From: "talanaky" <talanaky@...>
> >Reply-To: vantage@yahoogroups.com
> >Subject: [Vantage] Re: Parent part minimum qty affects lower level
parts?
> >Date: Tue, 28 Nov 2006 15:07:44 -0000
> >Carey, thanks.
> >But what do you mean by "If it is, it should the BOM components as
> >though they would be made as a 1-off"?
> >--- In vantage@yahoogroups.com, "Carey S" <rotary1@> wrote:
> > > In my case, it depends on whether the sub in the MOM is checked
as
> >PULL AS
> > > ASSEMBLY or not.
> > > If it is, it should the BOM components as though they would be
made
> >as a
> > > 1-off. However, if you uncheck this box, it should consider the
> >need of a
> > > premade sub, and in this case, use the planning values for the
sub
> >in the
> > > part/plant table.
> > > Carey
> > > >From: "talanaky" <talanaky@>
> > > >Subject: [Vantage] Parent part minimum qty affects lower level
> >parts?
> > > >Date: Mon, 27 Nov 2006 19:47:12 -0000
> > > >Scenario: An upper level Part, one that is sold to customers,
has a
> > > >minimum qty set, and the current stock level is below the
> >minimum. It
> > > >does have a complete BOM and MOM.
> > > >When PO Suggestions is run, will it generate suggestions for
the
> >lower
> > > >level parts if no job order has been created for that part? Or
> >will it
> > > >only take job orders into account when it creates suggestions,
> >even if
> > > >the inventory level is below the minimum?
_________________________________________________________________
> > > Get the latest Windows Live Messenger 8.1 Beta version.?Join
now.
> > > http://ideas.live.com
> MSN Shopping has everything on your holiday list. Get expert picks
by style,
> age, and price. Try it!
> http://shopping.msn.com/content/shp/?
ctId=8000,ptnrid=176,ptnrdata=200601&tcode=wlmtagline
