Part comments on Pick lists
One area to look into may be your BOM/MOM for the pick list you are trying
to print. When you are adding a material to the BOM in workbench, you can
select to override the part master comments for that material with your
own. If someone typed a space, or some other comment in that field, your
part master comments may not show on the picklist.
That's all I can think of...
Amy O'Malley
Manufacturing Process Engineer
Synovis Interventional Solutions
Lino Lakes, Minnesota
v 8.00.802
On 14 Sep 2005, Duane Kaufman wrote:
> Hi All,
> I have a (hopefully) easy-to-solve problem. I have comments I would like
> to have appear on a per-part basis on a pick list.
> I have entered comments as a Part comment for a certain part, and I see
> that both Manufacturing and Purchasing comments come through on a pick
> list using that part.
> I then tried it on another part, but the comments do no show up. Any
> ideas as to what I may be doing wrong?
> Thanks,
> Duane
Hi All,
Duane
NOTICE: This communication may contain privileged or other confidential information for the sole use of the designated recipients. If you have received it in error, please advise the sender by reply email and immediately delete the message and any attachments without reviewing, copying or disclosing the contents.
