I figured out so I thought I would pass it on.
There is a Answer Book #6539MPS but you still need to create a Sub Process
so you can call the Menu ID you attached the customization to.
Scott Litzau
Scott Litzau
Sent: Monday, June 16, 2008 10:02 AM
Subject: [Vantage] Part Tracker on MES - 8.03.305
I created a customized Part Tracker for the MES stations so that has
just the essentials needed on the shop floor.
Now I am trying to deploy this customization to the MES. I set up a Sub-
Process as a Non-Menu Item using the Program
Epicor.Mfg.UI.PartTracker.dll and choosing my customization I created.
I then set up a Process with the Called Process of
Epicor.Mfg.UI.PartTracker.dll and the calling process being
Epicor.Mfg.Menu.Mes and chooing the Menu ID I created in Sub-Process.
But when I run Part Tracker I get the Base program.
When I run Part Tracker while in Developer Mode the Key is OMGO3004.
But that is a security menu not a program so you can not tie a
customization to it.
Scott
Scott Litzau
Scott Litzau
Scott
