They acknowledged it is an issue and to fix it you have to do an event
that will cause a cst-adj event logged to the parttran table such as a
cost set roll-up or a cost adjustment for each affected part. This will
cause the last last cst-adj event to have the correct cost.
Butch
Of Lydia Coffman
Sent: Monday, September 26, 2005 8:40 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: Patch 6.10.530
Butch:
We just upgraded to 6.1 on 9/15/05 and have discovered this issue as
well.
Have you any word from Tech support yet?
Lydia
Sent: Wednesday, September 21, 2005 2:07 PM
Follow-up: Just tested the stock status report for 530 against 518. My
previous issue was fixed (without me messing up my standards by rolling
all the costs), but 138 out of 1858 parts have the wrong unit cost. I
reviewed the part transactions and the system is pulling out adj-cst
records created by the system for variances when jobs are closed. Tech
Support is looking into it.
Butch
Of Butch Menge
Sent: Wednesday, September 21, 2005 9:11 AM
When I was testing 529 I compared the stock status report to our current
version (518) and there were many discrepancies. After tech support
looked into it they told me the report is looking for the costs in the
PartTrans table and because of some of the records found in the table, I
would need to do a cost roll-up to fix the issue. We use standard
costing so that was not an option at the time. Now it is time to do our
annual cost roll-up so I'll be loading 530 and testing his solution.
Tech support also indicated there was a few other anomolies with the
stock status report but didn't get into it.
Butch
Of al2trace
Sent: Wednesday, September 21, 2005 5:34 AM
Subject: [Vantage] Re: Patch 6.10.530
We installed patch 530 moving from 518. On the Stock Status report,
it corrected the problem we were looking to fix, corrected one we
didn't know we had, and introduced a new problem. The new problem
effects some items with standard costing. The easiest way to test
for the error is to run the Stock Status report for today and
compare it to a Crystal report showing the standard cost of each
item. The reports should give the same answer for items using
standard cost but that was not always the case for us after
installing 530. (We use all 3 cost types. The fixes were for parts
with last and average costing.)
Support has our database. They have not said when or if it will be
fixed, just that they knew 530 had standard cost issues and this did
not fit with previous symptoms that they had seen.
Butch
Of Lydia Coffman
Butch:
well.
Lydia
Butch
Of Butch Menge
Butch
Of al2trace
--- In vantage@yahoogroups.com, "bbelzer42" <bbelzer@t...> wrote:
> I haven't installed it yet, but the major fix I have found, is
that it
> fixes the issue with scrap costing from 529.
> Every quote has incorrect data in the Worksheet. It calculates the
> scrap value incorrectly. This patch fixes that.
> HTH
> --- In vantage@yahoogroups.com, "Abe Klassen" <ak@m...> wrote:
> > I have installed it and have not noticed any change at all.
> > ----- Original Message -----
> > From: Terry Guanella
> > Sent: Monday, September 19, 2005 4:41 PM
> > Subject: [Vantage] Patch 6.10.530
> > Anyone who has installed patch 6.10.530 do you have any feed
back
> > positive or negative?
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> must have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services
goto:
> > SPONSORED LINKS Manufacturing software Membership database
> software Database mortgage software
> > Pda database software Database management software
Online
> database software
> > YAHOO! GROUPS LINKS
> > a.. Visit your group "vantage" on the web.
> > b.. To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > c.. Your use of Yahoo! Groups is subject to the Yahoo!
Terms of
> Service.
SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Online+d
atabase+software&c=6&s=185&.sig=AvWEwtBBb2CCZUYeLzjLVQ>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=On
line+database+software&c=6&s=185&.sig=8uEu2piLZhrmuaS0aRTs5A>
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Onli
ne+database+software&c=6&s=185&.sig=WxJOMUVfawa-Spj4srksIw>
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Online+da
tabase+software&c=6&s=185&.sig=8c6UocdSpoECWlSALplOdQ>
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
line+database+software&c=6&s=185&.sig=C2nNY1SnmwAiBO61ww9nTw>
Online database software
<http://groups.yahoo.com/gads?t=ms&k=Online+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+sof
tware&w4=Pda+database+software&w5=Database+management+software&w6=Online
+database+software&c=6&s=185&.sig=cYursVrba9nF7BBMh8EfUA>
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
SPONSORED LINKS
YAHOO! GROUPS LINKS
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
