Physical Inventory tag generation
Epicor 10.0.700.4
I’m generating tags for a physical inventory and selecting the option to print by
Bin ID / Part ID / UOM / Lot Number
However, when I print the tags they are printing by what appears to be a Part Number / Bin sort. I looked at the SSRS tag report to see if I can change the sort format but it appears to be sorting by tag number. Is this a known issue? How have others printed tags (I’m actually printing sheets at three per but that shouldn’t matter) and had them sort by bin number?
Mike
There was a SCR in 10.0.x where no matter what order you told it to
generate tags it would only do it one way. I can’t find the SCR number
right now, but I remember they were able to send me a fix.
When I get in the office I’ll look again to see if I can find it for you.
Norman Hutchins
Systems Administrator
Howell Laboratories, Inc.
SCR 89780 - Count Cycle Maintenance - Generate Tags does not create them
on the correct order as selected
Norman Hutchins
System Administrator
Like @nhutchins we ran into this too.
At the time we could not get a one-off from Epicor quick enough, so we created a new Report Style, copied the original report and manually forced the sorting in the report and then named the Report Style accordingly. This worked well. If we needed it we would have created a different variation for each sort needed, but only one was needed and settled on.
-Rick
www.getaligned.solutions
Thanks. For anyone else that needs it, the SCR is 89780. Support is sending me a one off.
