Hi All,
It appears that a lot of people are using MS Access to link to Vantage
tables.
I am assuming this is for reporting.
Is there an issue of database size and speed with MS Access?
Can you link to Vantage from the MS Access MSDE data engine?
Are there any other options for linking to Vantage for reporting?
Robert MacDonald
Information Technology Manager
Ground Effects Ltd.
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Jasper Recto
Sent: Friday, May 26, 2006 8:25 AM
To:
Subject: RE: [Vantage] Playing with MS Access and Macros
Wow,
I never saw that before.
THANKS!
Jasper
garyp@...]
Sent: Friday, May 26, 2006 8:14 AM
To:
Hi Jasper
When you link the ODBC table with the link manager you need to check the
save password box in the bottom right hand corner.
It will then connect with prompting for the password
Regards
Gary
Of Jasper Recto
Sent: 25 May 2006 22:12
To:
I use MS Access to connect to the Vantage database using link tables.
Every time I open the application it ask me to enter the password to
access vantage. Is there a way so that I can set the password and it
won't prompt for it again? I've tried using a File DSN but it does the
same thing.
Any ideas?
Jasper
maguirre@...]
Sent: Tuesday, May 23, 2006 3:55 PM
To:
My experience is that you can set up a macro to link (ODBC-read only if
preferred), extract (query-create table), and report in whatever format
supported by Access (plenty). The macro has passwords, etc. and you can
"hide" the macro from the user. The only thing that the user has to do
is click on a button to run the macro - no passwords, etc. to do and the
user gets the results with live data and no mess. The only set up is
ODBC and Access 2000 or higher. You can email me directly if you do not
know how to set up a macro with 6.1 or lower.
Mario Aguirre - IT Manager
Lakin General Corp., Inc.
Of Chris Clunn
Sent: Tuesday, May 23, 2006 1:36 PM
To:
We just went through this at our company.
You probably don't want to open up the keys to the kingdom (payroll &
accounting or other sensitive info) so you'll want to setup a new
Progress "user" and set permissions on specific tables. Then setup the
ODBC client for this "user". There is excellent documentation available
from Epicor on how to setup ODBC.
Once the ODBC is setup you can link to the Progress tables in Access.
Then setup query to run based on the spreadsheet value (although I
prefer using an Access Forms).
Something like this:
"SELECT fields FROM tables WHERE key_value = " & spreadsheet value & ";"
Of Ben Belzer
Sent: Tuesday, May 23, 2006 2:22 PM
To:
Subject: [Vantage] Playing with MS Access
Hi All,
Call me uneducated, but I need a little head start on using Access.
My thought was to create a spreadsheet for my sales dept where they can
enter a field and see data based on that field.
IE They can enter a part number and see how much we have in stock, and
what is on order... or something to that effect.
My question is, can I do this without the ability to change the data?
The last thing I want to do is edit the database on accident.
If so, can someone give me a little boost as to how I would set this up?
IE connecting to the database, making sure I am in read-only etc. I
just need the basics, and I can take it all from there.
Thanks in advance!
Ben Belzer
Inside Sales Manager
TCI Precision Metals
800.234.5613.W
310.323.1255.F
bbelzer@... <mailto:
bbelzer@...>
www.tciprecision.com <
http://www.tciprecision.com/>
http://groups.yahoo.com/group/vantage/files/>
SPONSORED LINKS
Manufacturing software
http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database
management software
http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
http://groups.yahoo.com/group/vantage> " on the web.
<mailto:
vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <
http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
SPONSORED LINKS
Database management software
YAHOO! GROUPS LINKS
<mailto:
Service <
This e-mail is for the use of the intended recipient(s) only. If you have
received this e-mail in error, please notify the sender immediately and then
delete it. If you are not the intended recipient, you must not use, disclose
or distribute this e-mail without the author's prior permission. We have
taken precautions to minimize the risk of transmitting software viruses, but
we advise you to carry out your own virus checks on any attachment to this
message. We cannot accept liability for any loss or damage caused by
software viruses.
Yahoo! Groups Links
Yahoo! Groups Links
