Gary,
If you are on version 5 their is a report for this. It is under the Job
Management Reports called "Subcontract Status". This report tells you what
Subcontract operations are out there. If a PO has be generated. If so what
it is and when it was received in. This is for Open Jobs only.
Sent: Friday, May 25, 2001 12:54 PM
Subject: RE: [Vantage] PO Watchdog Report
Gary,
If it is actually a subcontract operation on the job when you run PO
suggestions it should be creating a suggestion. These should be easy to see
in PO entry.
<http://rd.yahoo.com/M=202225.1433492.3029752.1269402/D=egroupmail/S=1700007
183:N/A=675622/*http://altfarm.mediaplex.com/ad/ck/1177-3936-1039-2?mpt=9908
12744> []
<http://us.adserver.yahoo.com/l?M=202225.1433492.3029752.1269402/D=egroupmai
l/S=1700007183:N/A=675622/rand=115702870>
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
Gary,
in PO entry.
> -----Original Message-----<http://groups.yahoo.com/group/vantage/files/.> Note: You must
> From: Gary Grenier [mailto:ggrenier@...]
> Sent: Friday, May 25, 2001 12:10 PM
> Subject: [Vantage] PO Watchdog Report
> Network Blitz
> All,
> I have been asked to write a report that shows subcontract
> operations for which no PO has been created. I guess we've had a
> couple of instances where the parts came back after the sub job
> was completed, and because there was no PO in the system,
> receiving didn't know which job the parts applied to. Does
> anybody have such a report? Thanks in advance.
> Gary Grenier
> IT Manager
> Bell Manufacturing Co.
> (207)784-2961 x245
> ggrenier@...
> and Crystal Reports and other 'goodies', please go to:
> have already linked your email address to a yahoo id to enable access.<http://docs.yahoo.com/info/terms/>
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>Yahoo! Groups Sponsor
12744> []
