Portal Under 5.2
You need the cd with customer connect. If you install customer connect
without entering the customer connect license code your customer connect
will be limited to the ePortal functionality.
Ronald van der Linden
Macroscoop
Sent: Wednesday, November 27, 2002 5:00 AM
Subject: [Vantage] Portal Under 5.2
I am in the process of testing our Vantage 5.2 setup before we do a
migration in early Feb next year. I need to find a way to set up Portal
under 5.2.
I have contacted Epicor and they are trying to find some info for me but
with out much luck as yet.
If someone out there is running it under 5.2 and can give me some Idea as to
what I need to do to get it running, that would be great.
I know that is included with 5.2 as part of the Customer Connect modual but
you can use it without purchasing Customer Connect.
Thanks in advance
Thx
Michael C.
Network Administrator
I am in the process of testing our Vantage 5.2 setup before we do a migration in early Feb next year. I need to find a way to set up Portal under 5.2.
I have contacted Epicor and they are trying to find some info for me but with out much luck as yet.
If someone out there is running it under 5.2 and can give me some Idea as to what I need to do to get it running, that would be great.
I know that is included with 5.2 as part of the Customer Connect modual but you can use it without purchasing Customer Connect.
Thanks in advance
Thx
Michael C.
