We are testing E10.1.600.4. We have found that if you toggle the “Print as New” to “Print as Changed” radio buttons in PO Entry that the system will automatically print the PO as a PDF to your screen. Is there a setting somewhere we have missed, or is the a new “feature” to this version? Has anyone else seen this behavior?
I tested this in 10.1.600.5 and toggling the radio button doesn’t print the PO to screen. It must be a bug in 10.1.600.4, or a feature depending how you look at it.
Thanks for the reply Jonathan. I’ll open a new case with Support.
