Ace_Man,
Hang on a minute. That's exactly what's suppose to happen.
"It just gave me repeated data where each job's oprseq are multiplied by how
many sequence from the JobOper to the JobOper2 table."
JobOper 040 --- JobOper 010
JobOper 040 --- JobOper 020
JobOper 040 --- JobOper 030
JobOper 040 --- JobOper 040
JobOper 040 --- JobOper 050
Filter for JobOper > JobOper2
JobOper 040 --- Job Oper 010
JobOper 040 --- Job Oper 020
JobOper 040 --- Job Oper 030
Now sort and group on the JobOper. Print the jobOper on the Group Footer
record.
JobOper 040 --- Job Oper 030 -- Group Footer Line.
Now turn off record lines from printing.
Your left with the operation and the prior operation.
Patrick Winter
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Ace_Man
Sent: Monday, March 13, 2006 8:17 AM
To:
Subject: [Vantage] Re: Priority Dispatch Report
Well, That didn't work. It just gave me repeated data where each job's opseq
are multiplied by how many sequence from the JobOper to the JobOper2 table.
Anyone else want to take a crack at how the regions from this report are
taken from the tables using Crystal Reports?
--- In vantage@yahoogroups.com, pjw@... wrote:
> The only way I have been able to figure out how to read prior or
subsequent
> operations with crystal or report builder is an alias table join
to joboper
> again calling it JobOper2 joining just using the company and job
so it lists
> all operations. Then filtering for JobOper seq > JobOper2 seq
gives you the
> prior. I have not tried this in crystal but you can do greater
than or less
> than joins which may remove the need for the filter.
> Good Luck.
> Patrick
Yahoo! Groups Links
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
