Problem with BAQ Report Designer
OK, I figured out the problem, self inflicted unfortunately.
Yesterday while working on a custom version of the traveler I had the
bright idea to shorten the folder named CustomReports to Custom.
That caused a problem with this process. I noticed the problem while
in the middle of creating this BAQ report and changed the folder name
back, but it was apparently too late to get the rpt file made. I
deleted the BAQ Report and started over and everything was fine this
time.
Thanks for the assistance.
Brian
--- In vantage@yahoogroups.com, "Brian Stenglein" <bstenglein@...>
wrote:
> I do not have that. I will try starting over from scratch.
> Thanks,
> Brian
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@>
> wrote:
> > As soon as you initially create your BAQ Report in the BAQ Report
> > Designer and you hit SAVE, Vantage will dump a blank, template
> Crystal
> > Report in \epicor\mfgsys803\Server\reports\CustomReports
> > Open it from there. It will be waiting for you.
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of Brian Stenglein
> > Sent: Friday, October 17, 2008 3:36 PM
> > Subject: [Vantage] Re: Problem with BAQ Report Designer
> > Vic,
> > When you say, Open the Crystal Report, when/how does that get
> created?
> > According to the instructions a blank template should appear when
I
> > choose "Design Crystal Report", but I'm not getting that.
> > Thanks,
> > Brian
> > wrote:
> > > Don't follow the training guide. When I used to teach the
class,
> > I'd
> > > change it up a little. I *never* use Generate Sample Data.
> > > Once you create your BAQ Query and BAQ Report, go to ACTIONS and
> > Test
> > > Report Form.
> > > Press the Preview button. It will generate XML data in your
> > > MFGSYSDATA\Reports folder. It will launch a blank report.
Close
> > it.
> > > Pick up that XML file in your Mfgsysdata\reports folder and
move
> it
> > > locally to your PC. A local working directory.
> > > Open the Crystal RPT. Hit F5 to Preview and point to that local
> > copied
> > > XML file. Add the BAQReportResult table in DB Expert. Save.
> Now
> > > design your report. If you need to add fields in the BAQ, do
so
> > and
> > > repeat this process and delete/rename the local copy of the
> > previous XML
> > > file while Crystal is CLOSED. Open CR again and hit F5 and it
> will
> > not
> > > find the previous XML file, so it'll prompt you to look for
it.
> Now
> > > point it to your revised XML and it'll update the necessary
> fields.
> > > Also always do a Verify Database under the Database menu in CR.
> > > HTH.
> > > Vic Drecchio
> > > ERP Administrator
> > > TIMCO Aviation Services
> > > Greensboro, NC
> > > Email: vic.drecchio@
> > > Office: 336.668.4410 x3091
> > > Mobile: 704.530.3092
On
> > Behalf
> > > Of Brian Stenglein
> > > Sent: Friday, October 17, 2008 3:08 PM
> > > Subject: [Vantage] Problem with BAQ Report Designer
> > > I'm trying to do my first BAQ Crystal report. I'm following
along
> > with
> > > the example in the Tools guide. After generating the sample
data
> > and
> > > clicking on Design Crystal Report it sounds like Crystal is
> > supposed to
> > > open with a blank report template with the rpt named and the
data
> > > connection made. When I do it, Crystal opens to the Getting
> Started
> > > screen and does nothing else.
> > > Anyone have an idea for me? I called support and they weren't
> much
> > help
> > > but sent their document with the steps to create a BAQ. One
thing
> > that
> > > differs between their document and the tools guide is the
location
> > of
> > > the Sample Data Directory. Where should that and the local
> reports
> > > directory be pointed to?
> > > Thanks,
> > > Brian Stenglein
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> > must
> > > have already linked your email address to a yahoo id to enable
> > access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> access. )
> Builder
I'm trying to do my first BAQ Crystal report. I'm following along with
the example in the Tools guide. After generating the sample data and
clicking on Design Crystal Report it sounds like Crystal is supposed to
open with a blank report template with the rpt named and the data
connection made. When I do it, Crystal opens to the Getting Started
Anyone have an idea for me? I called support and they weren't much
help but sent their document with the steps to create a BAQ. One thing
that differs between their document and the tools guide is the location
of the Sample Data Directory. Where should that and the local reports
Brian Stenglein
Don't follow the training guide. When I used to teach the class, I'd
Once you create your BAQ Query and BAQ Report, go to ACTIONS and Test
Report Form.
MFGSYSDATA\Reports folder. It will launch a blank report. Close it.
Pick up that XML file in your Mfgsysdata\reports folder and move it
Open the Crystal RPT. Hit F5 to Preview and point to that local copied
XML file. Add the BAQReportResult table in DB Expert. Save. Now
design your report. If you need to add fields in the BAQ, do so and
repeat this process and delete/rename the local copy of the previous XML
file while Crystal is CLOSED. Open CR again and hit F5 and it will not
find the previous XML file, so it'll prompt you to look for it. Now
point it to your revised XML and it'll update the necessary fields.
HTH.
Vic Drecchio
ERP Administrator
Greensboro, NC
Email: vic.drecchio@...
Of Brian Stenglein
Anyone have an idea for me? I called support and they weren't much help
but sent their document with the steps to create a BAQ. One thing that
differs between their document and the tools guide is the location of
Brian Stenglein
Vic,
created? According to the instructions a blank template should
appear when I choose "Design Crystal Report", but I'm not getting
that.
Brian
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
I'd
Test
> Report Form.
it.
copied
and
previous XML
not
> HTH.
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
Behalf
> Of Brian Stenglein
with
and
supposed to
help
that
of
> Thanks,
> Brian Stenglein
must
access. )
Builder
Designer and you hit SAVE, Vantage will dump a blank, template Crystal
Of Brian Stenglein
Vic,
When you say, Open the Crystal Report, when/how does that get created?
According to the instructions a blank template should appear when I
Brian
I'd
Test
> Report Form.
it.
copied
and
previous XML
not
> HTH.
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
Behalf
> Of Brian Stenglein
with
and
supposed to
help
that
of
> Thanks,
> Brian Stenglein
must
access. )
Builder
Brian
Crystal
Behalf
> Of Brian Stenglein
> Vic,
created?
> Thanks,
> Brian
> I'd
> Test
> > Report Form.
> it.
it
> copied
Now
> and
> previous XML
will
> not
Now
fields.
> > HTH.
> > Vic Drecchio
> > ERP Administrator
> > Greensboro, NC
> Behalf
> > Of Brian Stenglein
> with
> and
> supposed to
Started
much
> help
> that
> of
reports
> > Thanks,
> > Brian Stenglein
> must
> access. )
> Builder
must
access. )
Builder
Dear Brian:
The instructions in the Epicor Tools User Guide are too basic and not
much help. Epicor publishes an AnswerBook on this topic which is
much greater help.
Go to the Epicor website and print out AnswerBook # 1705MPS
titled "BAQ Instructions for creating a Crystal Report from a BAQ in
BAQ Report Designer".
In Part B of these instructions, they tell you to Define the Report
Options. You need to verify 3 locations: the location of your CR
executable, the location of your Sample Reports Directory, and the
location of your Local Reports Directory.
You need to (1) make sure that these are correct and (2) write down
the complete path of your Sample Data directory because you will need
the location of the Sample Data in Part G of the instructions when
you design your Crystal Report.
I have found that the defaults for these 3 directories are not always
consistent. I always check them. For example, I needed to change my
CR executable path from a v11 directory to a v11.5 path. And, if you
are set up for "Multi-Company", the default will change according to
what company you are working in.
If you follow this Answerbook precisely, you should be able to create
a BAQ Report as Epicor intended.
And as you assumed, if all of your directories are pointed correctly,
then the "Design Crystal Report" command should launch CR and
directly open a blank.rpt file. You are correct; it should not be
opening to the "Getting Started" page.
Good luck.
Lynn
> Thanks,
> Brian
> Crystal
> Behalf
> > Of Brian Stenglein
> > Vic,
> created?
I
> > Thanks,
> > Brian
class,
> > I'd
> > Test
> > > Report Form.
Close
> > it.
move
> it
> > copied
> Now
so
> > and
> > previous XML
> will
> > not
it.
> Now
> fields.
> > > HTH.
> > > Vic Drecchio
> > > ERP Administrator
> > > Greensboro, NC
On
> > Behalf
> > > Of Brian Stenglein
along
> > with
data
> > and
> > supposed to
data
> Started
> much
> > help
thing
> > that
location
> > of
> reports
> > > Thanks,
> > > Brian Stenglein
You
> > must
> > access. )
> > Builder
> must
> access. )
> Builder
