Ryan:
My calculations don't need to be as exact as yours, so no, I haven't had any
problem with that. We pay in 1/4 hr increments, so it works fine.
I hope you get it straightened out - I'm sure it's frustrating.
Julie
Julie
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, May 24, 2005 8:51 AM
Subject: [Vantage] Re: Problems with 562 Patch
> Thanks for the response, Julie. I'm not even sure how long the lunch
> thing was going on for us...we just noticed it last week. For all I
> know, it could have been happening for awhile. Our situation is
> exactly the same. All of our shifts work just fine except for the
> night shift.
> Have you had any issues with the time calculation? When we had a 10
> hour shift, this never happened, but as soon as we changed our shift
> times to where the total hours were 9.92, we started experiencing the
> problem.
> Thanks.
> Ryan
> --- In vantage@yahoogroups.com, "Julie Lehmann" <jlehmann@m...> wrote:
> > I don't know about all of the other things you mentioned, but as
> far as the
> > 2nd shift lunch break - that has never worked right for us. It's
> very
> > weird, because my 1st & 2nd shifts are set up identical with the
> lunch break
> > etc., but if a 2nd shift person leaves during their lunch, it never
> has
> > treated it correctly (like it does for 1st shift). Luckily, it's a
> small
> > group here and I am able to catch it. We are on 6.1 also, and I
> guess my
> > point is that I don't believe that issued is related to your new
> > patch.......
> > Julie
> > Mercury Minnesota Inc.
> > From: "rmrindler" <rrindler@n...>
> > Sent: Tuesday, May 24, 2005 8:22 AM
> > Subject: [Vantage] Problems with 562 Patch
> > > I was wondering if anybody else has installed and had any problems
> > > with Vantage 6.1's 562 patch or Progress SP9 with the hotfix? We
> > > have been experiencing some problems the last couple of weeks with
> > > the payroll/labor collection module, and now some other issue have
> > > cropped up since installing the patches.
> > > One problem we have had is if an employee on the night shift
> clocks
> > > out & back in during the lunch period, they are getting paid for
> the
> > > remainder of the lunch period after they clock back in.
> > > Another problem we have had is our day shifts are setup for 9.92
> > > hours. If we go in to update either the labor or payroll detail
> for
> > > an employee, even though the clockin & clockout times are correct,
> > > the time gets calculated as 9.91 hours (instead of 9.92).
> > > In order to try and fix these problems, Epicor recommended that I
> > > install the latest patches as well as do a dump & load & reindex
> of
> > > the database (pretty standard answer). I did not want to do this
> all
> > > at the same time so I could identify what, if anything, fixed the
> > > problem. This past weekend, I started with installing the latest
> > > Vantage patch and Progress patch & hotfix, and now I am
> experiencing
> > > some other problems:
> > > 1) The stock status report does not list all of the part numbers,
> and
> > > it subtotals some part numbers but not others
> > > 2) It is not allowing us to split jobs the way we used to
> > > 3) The system is working more slowly in general (both server and
> > > clients)
> > > I am planning on doing the dump & load & reindex this Friday
> night,
> > > but before I do, I wanted to see if anybody else has experienced
> any
> > > similar issues before. At this point, I am very concerned about
> the
> > > integrity of the database.
> > > Any information would be much appreciated.
> > > Thanks!
> > > Ryan Rindler
> > > Norwood Tool Company
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > have already linked your email address to a yahoo id to enable
> access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > > Yahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
