They use a "Dataserver" layer that translates the native Progress calls into
calls to the selected third party database. I'm not absolutely sure if they
still require that the meta schema reside in a Progress database but,
frankly, I would be surprised if it doesn't. I can't imagine a business
situation where it would make sense for Progress to create a database
agnostic system and not make certain that their native DBMS would radically
outperform other alternatives.
Michael
Sent: Wednesday, September 08, 2004 8:09 AM
Subject: RE: [Vantage] Re: Progress-OpenEdge
But if I am not mistaken it still uses ODBC to connect to those Databases
with the exception of Progress. Is this correct? If it does, then I would
assume that there is still the same issues with performance that exists with
SQL Server for example and Vantage 5.x and 6.x.
Jeremy
Sent: Wednesday, September 08, 2004 11:05 AM
OpenEdge includes Progress 10 but is more than just a database upgrade.
OpenEdge is Progress Software's effort to move to a J2EE compliant
application server architecture where application logic is abstracted from
the presentation layer and database and is encapsulated in a middle tier of
server side business objects.
Earlier versions of Progress attached business logic to both the
presentation layer with the Progress 4GL and to the Progress database in the
form of triggers. Open Edge moves the business logic to an application
server layer that is independent of its presentation or persistence. The
result is to make the use of a database (Progress, Oracle, SQL Server,
etc...) or a presentation (ie. Java, web, etc...) entirely up to the needs
of the user.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
This email, and any attachments thereto, is intended only for use by the
addressee(s) named herein and may contain legally privileged and/or
confidential information. If you are not the intended recipient of this
email, you are hereby notified that any dissemination, distribution or
copying of this email, and any attachments thereto, is strictly prohibited.
If you have received this email in error, please immediately notify me by
telephone and permanently delete the original and any copy of any email and
any printout thereof.
Sent: Wednesday, September 08, 2004 5:22 AM
Ann,
My understanding is that OpenEdge is effectively Progress 10. The Beta CD
says nothing about progress, and the progress directory is named for Open
Edge (OE10...). I believe this is just Progress 10 by another name.
This is not official Progress or Epicor line, this is just my understanding.
Aaron Hoyt
Hittite Microwave
Sent: Tuesday, September 07, 2004 3:27 PM
Subject: [Vantage] Re: Progress-OpenEdge
Will OpenEdge be included in the Progress upgrade that we receive
from Epicor, or is it a separate purchase/option?
Thanks!
Ann
AMFAB
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...>
wrote:
in between the user interface (written with .Net) and the actual
database. This gives Vantage the flexibility to support other
databases (Oracle, DB2, SQL Server, etc...) without messing with the
data rules. The Progress RDBMS can still be used and probably would
be for most Vantage sites (better support, faster perhaps, easier
admin). Because the rules are independent from the user interface
this will afford a lot of flexibility to customize things. The .Net
interface also will hook up well with Crystal 10/11 making that the
choice for the most robust reporting requirements. There are also
the other query and export tools that might replace the more simple
RB reports.
Also
attending Perspectives would certainly fill in some concept gaps and
allow grilling the Epicor experts one-on-one.
in all the tables being used and even then they will not run from
within the Vantage user interface. Just because it is technically
possible even in a limited way does not mean it is practical. I
will continue to write RB on an "as needed" basis, mostly for quick
hit one-off reports but at some point will start developing all new
reports in Crystal. Hardware infrastructure issues (servers and
client PC replacements) will put Vantage 8.0 off for us until at
least 2006 so I have a good 18 months to start converting the
400+
RB reports to Crystal. But I am not counting on any use of RB past
Vantage 6.1 miracle or not.
must have already linked your email address to a yahoo id to enable
access. )
76/D=groups/S=1705007183:HM/EXP=1094665135/A=2319498/R=0/SIG=11thfntf
p/*http://www.netflix.com/Default?mqso=60185352&partid=5285298>
click here
466>
Service <http://docs.yahoo.com/info/terms/> .
You must have already linked your email address to a yahoo id to enable
access. )
(1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=1298h5aap/M=295196.4901138.6071305.3001176/
D=groups/S=1705007183:HM/EXP=1094671632/A=2128215/R=0/SIG=10se96mf6/*htt
p://companion.yahoo.com>
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=group
s/S=:HM/A=2128215/rand=201401156>
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service <http://docs.yahoo.com/info/terms/> .
------------------------ Yahoo! Groups Sponsor --------------------~--> Make
a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/PhFolB/TM
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Michael
Jeremy
of the user.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Ann,
Aaron Hoyt
Hittite Microwave
Thanks!
Ann
AMFAB
wrote:
> OpenEdge is a new "layer" used by Vantage 8.0. It contains thebusiness "rules" as well as the .Net interface. So it sort of sits
RB reports.
>your CAM for a copy of the "Sonoma Architecture Whitepaper".
> If you don't have a copy already I would highly recommend asking
Also
>reports run with Progress 10 but only if there are no field changes
> My understanding is that there may be a way to make existing RB
400+
>OpenEdge
> -Todd C.
> From: amfabllc [mailto:amfab@a...]
> Sent: Tuesday, September 07, 2004 12:38 PM
> Subject: [Vantage] Progress-OpenEdge
> I just received a mailing for Progress classes. One of the things
> in their agenda is 'OpenEdge'. "10 Good Reasons to Move to
> 10";-it notes data comparing Progress Versions 8 and 9 withOpenEdge
> 10 on identical hardware performing identical tasks. It alsotalks
> about "Administering/Tuning Your OpenEdge RDBMS Database forin
> Reporting". It does not appear to replace Report Builder because
> another paragraph it talks about "Enterprise Information:Making
> Sense of Your Data - ...This session explores OpenEdge tools foressential.
> transforming data to information. Since data has little relevance
> by itself, effectively generating usable information is
> This session will also feature information and a demonstration onpossible
> Crystal Reports."
> Anyone know anything about Progress OpenEdge? We are still on
> Vantage 5.0 and NT4, I am trying to gather as much info as
> to make the best decisions when update time does come, possiblyall
> the way to 8.0. If I do stop at 6.1 it will be due to thehundreds
> of Report Builder Reports that I have written and are used daily.you
> I'm still waiting for a miracle on that one.
> In 8.0, will current Report Builder reports run at all - meaning
> just can't add any new ones? Or does 8.0 not allow you to run anyYou
> RB reports, new or old?
> And while I am asking various off the wall questions, what is the
> formula to use when deciding the limit on how many workstations
> should access a terminal (2003) server without overloading it?
> Just Curious,
> Thanks so much!!
> Ann Rohyans
> AMFAB
> amfab@a...
access. )
> (1) To access the Files Section of our Yahoo!Group for ReportBuilder and Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage servicesgoto:
><http://us.ard.yahoo.com/SIG=1298d9o5h/M=298184.5285298.6392945.30011
> ADVERTISEMENT
click here
> <http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=:HM/A=2319498/rand=435058
466>
> _____
> Yahoo! Groups Links
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
>Terms of
access. )
ADVERTISEMENT
click here
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
