Thanks to everyone for the detailed pointers. :-)
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Tuesday, April 28, 2009 9:54 AM
Subject: Re: [Vantage] ProPath, Live vs. Test, and BPMs
The default Vantage install is such that any BPM method directives apply to ALL Vantage DBs on the server.
This means that if you develop a BPM in the TEST database, once enabled it will apply and run in the LIVE and TRAIN databases as well. It will therefore cause problems if you want to test BPMs while developing them, or if you are running several databases, each with different BPM requirements.
To enable BPM to apply to one particular DB, you need to set up the Appservers to have unique BPM folders in their PROPATH.
The steps below explain how to change the Train DB to use a different BPM folder.
1. In Progress Explorer, right click on the MFGTRAIN803 Appserver.
2. Select Properties
3. Click on Agent ' General
4. The PROPATH should be similar to the following: "E:\epicor\mfgsys803\custom,E:\epicor\mfgsys803\bpm,:\epicor\mfgsys803\Server\custom,E:\epicor\mfgsys803\Server,E:\epicor\mfgsys803"
5. Change the BPM element of this to a unique path i.e. "E:\epicor\mfgsys803\custom,E:\epicor\mfgsys803\TRAIN\bpm,:\epicor\mfgsys803\Server\custom,E:\epicor\mfgsys803\Server,E:\epicor\mfgsys803"
N.B. It is IMPERATIVE that the path ends in "BPM"
6. Repeat Steps 2 - 5 for the MFGTRAIN803ProcessServer and MFGTRAIN803TaskAgent
7. From Windows Explorer, create the directory specified in this instance "E:\epicor\mfgsys803\TRAIN\bpm"
8. Restart the Appservers. Users will need to be logged off for this.
9. Resave any BPMs created in the Train DB.
Background
When building a BPM method directive, data is stored in the Vantage DB. When a BPM directive is enabled and saved, the data is processed and a Progress program is generated to disk. The program is generated into the directory specified in the Appserver's PROPATH (folder ending in BPM). When Business Object methods are called via Web Services or a Vantage client, any BPM directives which exist for this method are located first in the propath and are therefore executed prior to base Business Object methods.
Sent: Tuesday, April 28, 2009 9:38:40 AM
Subject: [Vantage] ProPath, Live vs. Test, and BPMs
How does one configure OpenEdge to keep separate BPMs that one creates
in one database (e.g. Test) from impacting the live production
environment?
Rich Riley mentioned this in a talk he gave at Perspectives:
http://www.epicor com/Customers/ Perspectives/ Perspectives% 202008%20Prese
ntations/Vantage_ Vista/8%2003% 20400%20Technolo gy%20Tips% 20and%20Tricks% 2
0-%20Configuration. ppt
But gave no specifics..
-bws
Picometrix
bspolarich@advanced photonix. com
<mailto:bspolarich@advanced photonix. com> ~ 734-864-5618 ~
www.advancedphotoni x.com <http://www.advanced photonix. com>
Background
environment?
-bws
Picometrix
