Pull as assembly question
You issue it the same way you normally would. You have to select the correct asy level (the one the assembly APPEARS IN in your job details - not the Asy level the subassy leg details in the job are assigned).
Â
Rob
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, October 24, 2012 3:09 PM
Subject: [Vantage] Pull as assembly question
Â
Vantage gurus,
We are still having issues trying to find pure cost elements in our job.
I received this response awhile back:
"Mike if you produce a subassembly to stock, it will treat it as a material, however, when you issue that subassembly (as a material) to the parent job the material, labor, overhead, etc costs are broken back out again. If you create subassemblies in different jobs and those jobs have a demand link that receives them to the upper level assembly it will also include those individual cost buckets"
My question is how do you issue a subassembly as a material in Vantage 8.03?
Vantage gurus,
Mike, if your top level assembly is a pull as assembly, all your sub-assemblies will appear as if they are all being produced at once. If you go into issue materials screen, you can check the box which says "include sub-assemblies" and it will issue the assembly along with the individual materials.
Â
Vantage gurus,
Hi Mike,
When you are creating a BOM you can choose to manage subassemblies as a part of the job, or coming from a side job. Pull As Assembly means side job. In other words, it will require a side job to build that subassemby for the parent job. This will require you to issue the completed subassembly back to the parent job.
It is true, in V8 a side job accumulates the 5 cost elements and enters inventory that way. Then, when you issue it back to the parent job it consolidates to only the material cost element. However, you can see the cost breakout of the issued material in the Job Tracker.
In E9 there is a flag you can set to keep the original cost elements during issuing to the parent job.
Does this help?
Ross
Is this a V9 thing as I do not see this in our Vantage 8.03....
From: vantage@yahoogroups.com [vantage@yahoogroups.com] on behalf of Mark Wagner [mjfw2003@...]
Sent: Wednesday, October 24, 2012 2:27 PM
Subject: Re: [Vantage] Pull as assembly question
From: Mike Abell <mabell@...<mailto:mabell%40flexial.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Vantage gurus,
Mark's answer is a V9 thing....
Â
Â
M. Manasa Reddy
manasa@...
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Abell
Sent: Wednesday, October 24, 2012 4:34 PM
Subject: RE: [Vantage] Pull as assembly question
Vantage gurus,
Yes, thanks Manasa, my Vantage versus E9 becomes blurry sometime!
Sent: Wednesday, October 24, 2012 5:47 PM
Â
Â
Â
M. Manasa Reddy
mailto:manasa%40weldcoa.com
630.806.2000 x1515
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Mike Abell
To: mailto:vantage%40yahoogroups.com
From: mailto:vantage%40yahoogroups.com [mailto:vantage%40yahoogroups.com] on behalf of Mark Wagner [mailto:mjfw2003%40yahoo.com]
From: Mike Abell <mailto:mabell%40flexial.com<mailto:mabell%40flexial.com>>
To: "mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>" <mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Vantage gurus,
