Mike, check in your vendor tracker to see if the first vendor listed is a
blank line. If so go into the Vendor master and delete the blank vendor.
If blank vendor is loaded, then it is a valid vendor for your PO's.
Sent: Monday, September 16, 2002 4:28 PM
Subject: [Vantage] Purchase Order's with no Vendor Listed
We are using Vantage 5.00.334. Is anyone else having problems with Purchase
orders being created without a vendor attached? When we look at open PO's
through the order entry browser there are PO's listed that have no Vendor ID
or Name attached. We are not able to open these in order entry because we
get errors that say "**No POHeader record is available. (91)" and then the
next error is " Error attempting to push run time parameters onto the stack.
(984)" I called support and they said that they would send a program to
close the orders, but I would prefer to fix the problem.
Support also mentioned that the problem may have come from a vendor with a
"blank" name and ID, but I ran a report builder report to show the vendor ID
for one of these orders and it came back with an ID of "0".
Thanks in advance:
Mike Moloney
CONFIDENTIALITY : This e-mail and any attachments are confidential and may
be privileged. If you are not a named recipient, please notify the sender
immediately and do not open any attachments hereto, disclose the contents of
this e-mail or the attachments if any thereto, to another person, use it for
any purpose or store or copy the information in any medium.
Thanks in advance:
Mike Moloney
