At 09:24 AM 1/4/2002 -0500, you wrote:
In 5.0 and up, a buyer will only see their own suggestions and those for
other buyers that they have PO update privileges for. For subcontract ops,
the buyer will be pulled from the operation code. I'm not sure what
happens if that's not filled in - there may not be a suggestion generated
at all. 5.0 also added a "default buyer" check box to the buyers
table. That may be what's used in that case (I haven't played with it that
extensively since our 5.0 upgrade.)
You might also double check that there isn't already a PO written for the
op. If so, it might be in the Change Suggestions rather then the New
Suggestions. I have a nice report for change suggestions, if anyone would
like.
-Wayne Cox
>I have a work order with a subcontract operation that is not generatingWhich version of Vantage are ya' running?
>a purchasing suggestion. I cannot determine why a suggestion is not
>generated. Does anyone have ideas what could be wrong?
like.
-Wayne Cox
