Hi
This is more like a poll than a request for help. How many documents do you have per customer in Epicor/Kinetic?
We’ve seen that the Invoices grids on Customer Tracker become unusable after some transactions. Meaning the pull of info takes up to 5 minutes, which render the screen unusable.
We saw this performance issue getting worse on Kinetic and we have a support case, but it seems it might be discarded as regular use/capability.
One example is a customer with 9K invoices, only 3 years of transactions and that section of customer tracker is now completely ignored due to this performance issue. We had to create customizations on this tracker to pull the data directly from a BAQ.
So, if you can share your experience, I might have peace of mind regarding this ![]()
By the way, I did run a trace to check this and of course, the amount of data transfered is important. The culprit is the CreditManager BO, which calls GetInvoicesEx and passes a dataset AllocDepositTrk, quite big and then get the response much bigger of course. Not sure where the hold up is. Maybe is getting the AllocDespositTrk dataset filled, but I think is more related to the actual process in the BO. Maybe it is making row by row checking? Fiddler reports 116MB on that network transaction, Still it wouldn’t impact as 5 minutes in case of transfer, would it?
