Query Export - Continuous Process
Yes, I apologize, Epicor Service Connect User Guide.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Blake Clemens
Sent: Monday, April 06, 2009 8:36 AM
Subject: RE: [Vantage] Query Export - Continuous Process
I have the Service Connect User's Guide. Is that the same thing?
Thanks for the help on this Rob. I really appreciate it.
Blake Clemens
DMC
Behalf
Of Rob Bucek
Sent: Monday, April 06, 2009 9:25 AM
If you have the service connect tools guide there is a helpful example
in there on setting up a BPM workflow. If you're doing workflows Id
recommend getting it. Since it sounds like you really won't be
filtering on any particular conditions, just sending data out as it's
added, your BPM should be fairly straight forward. If that was a true
statement, on your update method of the UD table you'll create a
pre-process action (you won't need any condition) which will be enable
post process. In your post process on conditions, set to enabled from
(pick your pre-process). Under actions choose Service connect workflow,
and set the parameters as required.
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> <http://www.dsmfg.com/
<http://www.dsmfg.com/> > >
Behalf
Of Blake Clemens
Sent: Monday, April 06, 2009 8:03 AM
Thanks Rob!
I was afraid that was going to be the answer. I have not set up a BPM
yet but am eager to learn to do so. Is there any documentation out
there to get me started? I downloaded the document from Epicor but like
most of their documentation it doesn't make any sense.
Blake Clemens
DMC
Behalf
Of Rob Bucek
Sent: Monday, April 06, 2009 8:51 AM
That's a perfect scenario for a BPM. I have a couple BPM's sending data
sets to a service connect workflow. There are business methods for UD
tables, just use the update method.
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/> > <http://www.dsmfg.com/ <http://www.dsmfg.com/>
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > > <
<http://www.dsmfg.com/> > > > >
Behalf
Of Blake Clemens
Sent: Friday, April 03, 2009 1:56 PM
Subject: [Vantage] Query Export - Continuous Process
I have a problem... Here is my scenario... We are on Vantage 8.03.405A.
I used a user defined table (UD01) to create a menu. This menu's only
purpose is to store a Sales Order Number and a Date. I then created a
query to show all Sales Order Numbers and Dates entered in this User
Defined Table. The query works fine. I would like to export this
query. So I decided to use the Business Activity Query Export Process.
I want this query to be exported continuously, let's say every 60
seconds. I created a new schedule in the System Agent that runs every 60
seconds. I submitted the query to this schedule via the Business
Activity Query Export Process and checked the "reoccurring" check box.
I restarted the appservers. I see the schedule in the System Monitor
but the file doesn't export. Actually, it exports one time right after
I restart the appservers but it won't export multiple times. My
intention is for Service Connect to grab this exported query and process
it through a work flow that I will create. What am I missing here? I
would like to think that this is fairly simple to set up. Although it
is Friday and my brain is only running at 10% of its potential which is
only 10% anyways. Any help here would be greatly appreciated.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
***Privileged & Confidential***
This email, together with any attachments, is intended for the named
recipient(s) only and may contain privileged and confidential
information. If received in error, please inform the sender as quickly
as possible and delete this email and any copies. If not an intended
recipient of this email, you must not copy, distribute or rely on it,
and any form of disclosure, modification, distribution and/or
publication of this email is prohibited.
Unless stated otherwise, this email represents only the views of the
sender and not the views of Delmarva Millwork Corporation.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
With numbers like that for brain power you may have to hang it up for the
day. Cuz it seems like the group is rather dead this after noon.
I would like to know how to do this as well cuz I have some problems I would
like to solve in the same manor.
We may get lucky and some one on the west coast where the day is still young
may have some brain power left.
I have a SC Choice that is giving me hell that I can't figure out.
~Charlie
_____
Blake Clemens
Sent: Friday, April 03, 2009 2:56 PM
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Charlie,
I believe you are correct. I'm outta here.
Blake Clemens
DMC
Of Charlie Wilson
Sent: Friday, April 03, 2009 3:07 PM
the
would
young
~Charlie
_____
Behalf Of
Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Rob Bucek
FAX: 715-284-4084
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Thanks Rob!
Blake Clemens
DMC
Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Rob Bucek
FAX: 715-284-4084
Of Blake Clemens
Thanks Rob!
Blake Clemens
DMC
Behalf
Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Blake Clemens
DMC
Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
Behalf
Of Blake Clemens
Thanks Rob!
Blake Clemens
DMC
Behalf
Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > > >
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
