Hopefully a simple question. We discovered a whole bank of orders where the ReadyToFulfill flag is checked on the OrderHed but it is not checked on the OrderRel. I was under the impression that if you checked the header flag, it would automatically check all the releases… However, I do understand you can individually uncheck or check the releases. In any event, a whole range of orders that were all evidently copied from 1 order are setup without the RTF flag checked on OrderRel. It’s not on purpose. Is there some other Epicor logic that will do this? Any ideas?
i dont believe that there is any built in logic. I have seen companies create BPMs that will update all releases when someone checks/unchecks the ready to fulfill checkbox on the order header.
