Rename a label in custom code
I did figure that out, I was able to delete that and got rid of the error, when I opened the form, the customization was still hidden because all my fields were gone.  I just recreated it, i needed the practice anyway!
Thanks!
John
On Tuesday, January 28, 2014 4:49 PM, Ted Koch <tkoch77@...> wrote:
<div id="ygrps-yiv-1134814259yiv2525710362ygrp-text">
  <div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:8pt;background-color:rgb(255, 255, 255);">You should be able to go in Customization Maintenance, search for the customization, Actions &gt; Show Custom Data, and in the Controls Tab try renaming the control.<br clear="none"><div><span><br clear="none"></span></div><div><br clear="none"></div>  <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:8pt;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:12pt;"> <div dir="ltr"> <div style="margin:5px 0px;padding:0px;border:1px solid rgb(204, 204, 204);height:0px;line-height:0;font-size:0px;" class="ygrps-yiv-1134814259hr"></div>  <font size="2" face="Arial"> <b><span style="font-weight:bold;">From:</span></b>
j.sieracki <j.sieracki@…>
Sent: Tuesday, January 28, 2014 12:34 PM
Subject: [Vantage] Re: Rename a label in custom code
Hello,
I've got this same issue, what do I need to enter in to fix it?
— In vantage@yahoogroups.com, "Anitha" <anithayedavalli@…> wrote:
> Error Detail
> --------compile errors------------
>  Error: CS0102 - line 188 (188) - The type 'Script' already contains a definition for 'epiLabelC1'
>  ** Compile Failed. **
> Stack Trace
>    at Epicor.Mfg.UI.Customization.CustomScriptManager.CompileCustomScript(Boolean loading)
> — In vantage@yahoogroups.com, "Anitha" <anithayedavalli@> wrote:
> > How do you rename a label in custom code.I have two custom labels
with the same name(label1) and now the form doesnt load.All I can do is change one of the label name in custom code.How can I do that?
> > Tried label1.Text="sd" and label1.Name="sd" but no luck.
> > Thanks.
Useful links for the Yahoo!Groups Vantage Board are: ( Note:  You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/
(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahooGroups Links
<> To visit your group on the web, go to:
> Your email settings:
    Individual Email | Traditional
<> To change settings online go to:
    http://groups.yahoo.com/group/vantage/join
    (Yahoo! ID required)
> To change settings via email:
    vantage-digest@yahoogroups.com
    vantage-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
    <a rel=“nofollow” target=“_blank” href="mailto:vantage-unsubscribe@yahoogroups.com" shape=“rect”
<*> Your use of Yahoo Groups is subject to:
    Yahoo Terms International | Yahoo
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362 -- #ygrps-yiv-1134814259yiv2525710362ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mkp #ygrps-yiv-1134814259yiv2525710362hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mkp #ygrps-yiv-1134814259yiv2525710362ads {
margin-bottom:10px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mkp .ygrps-yiv-1134814259yiv2525710362ad {
padding:0 0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mkp .ygrps-yiv-1134814259yiv2525710362ad p {
margin:0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mkp .ygrps-yiv-1134814259yiv2525710362ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-sponsor #ygrps-yiv-1134814259yiv2525710362ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-sponsor #ygrps-yiv-1134814259yiv2525710362ygrp-lc #ygrps-yiv-1134814259yiv2525710362hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-sponsor #ygrps-yiv-1134814259yiv2525710362ygrp-lc .ygrps-yiv-1134814259yiv2525710362ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362activity span {
font-weight:700;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362activity span span {
color:#ff7900;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362activity span .ygrps-yiv-1134814259yiv2525710362underline {
text-decoration:underline;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362attach div a {
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362attach label a {
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362bold a {
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 dd.ygrps-yiv-1134814259yiv2525710362last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 dd.ygrps-yiv-1134814259yiv2525710362last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 dd.ygrps-yiv-1134814259yiv2525710362last p span.ygrps-yiv-1134814259yiv2525710362yshortcuts {
margin-right:0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362attach-table div div a {
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362attach-table {
width:400px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362file-title a, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362file-title a:active, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362file-title a:hover, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362file-title a:visited {
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362photo-title a, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362photo-title a:active, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362photo-title a:hover, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div.ygrps-yiv-1134814259yiv2525710362photo-title a:visited {
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 div#ygrps-yiv-1134814259yiv2525710362ygrp-mlmsg #ygrps-yiv-1134814259yiv2525710362ygrp-msg p a span.ygrps-yiv-1134814259yiv2525710362yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362green {
color:#628c2a;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 o {
font-size:0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362photos div {
float:left;width:72px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362reco-category {
font-size:77%;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362reco-desc {
font-size:77%;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 .ygrps-yiv-1134814259yiv2525710362replbq {
margin:4px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mlmsg select, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 input, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mlmsg pre, #ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 code {
font:115% monospace;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-mlmsg #ygrps-yiv-1134814259yiv2525710362logo {
padding-bottom:10px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-msg p#ygrps-yiv-1134814259yiv2525710362attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-reco #ygrps-yiv-1134814259yiv2525710362reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-sponsor #ygrps-yiv-1134814259yiv2525710362ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-sponsor #ygrps-yiv-1134814259yiv2525710362ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-sponsor #ygrps-yiv-1134814259yiv2525710362ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1134814259 #ygrps-yiv-1134814259yiv2525710362 #ygrps-yiv-1134814259yiv2525710362ygrp-vital ul li:last-child {
border-right:none !important;}
How do you rename a label in custom code.I have two custom labels with the same name(label1) and now the form doesnt load.All I can do is change one of the label name in custom code.How can I do that?
Thanks.
Error Detail
Stack Trace
> Thanks.
Never Mind.Figured it out.Added custom code to remove the control.
> Thanks.
Anitha,
If this are custom labels that you added, why did you need to add code to
remove the control. Can't you just open the form in customization mode and
delete the 2nd control.
As an aside, I've run into problems before when adding custom controls with
it giving the same name. As a result, I've just gotten in the habit of
renaming controls to something more meaningful when I add them, so instead
of "epiTextBoxC1", it will be "ProperlyNamedField".
Kevin Simon
Anitha
Sent: Thursday, April 07, 2011 9:09 AM
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Anitha"
> Thanks.
I saved the form without testing the custom code.The new customized form wouldn't load unless I had to remove one of the labels or rename it.So I had to write code to remove the label.
--- In vantage@yahoogroups.com, "Kevin Simon" <ksimon@...> wrote:
> Anitha,
> Kevin Simon
> Anitha
> > Thanks.
Hello,
> Error Detail
> Stack Trace
> > Thanks.
You should be able to go in Customization Maintenance, search for the customization, Actions > Show Custom Data, and in the Controls Tab try renaming the control.
Hello,
> Error Detail
> Stack Trace
> > Thanks.
(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
<*> To change settings online go to:
<*> To change settings via email:
    http://info.yahoo.com/legal/us/yahoo/utos/terms/
