Progress database, Yep. It is truncating one digit off the end. It gives
these errors(warnings) in Report Builder then runs the report. I have since
found if you run the report from a Vantage menu you don't get the errors. It
appears only Report Builder can't handle the changes.
Cliff
Sent: Tuesday, June 24, 2003 5:18 AM
Subject: RE: [Vantage] Report Builder and Vantage 6
In updating to VN 6.00, there was change to the CreditOverrideLimit field.
The size was increased to a value that Report Builder cannot read.
Can you look at the database and show exactly what the field specifications
were changed to. I can't believe the database can set a field to a size
progress or report builder can't deal with. Are you running a progess
database?
Patrick Winter
Sent: Monday, June 23, 2003 4:44 PM
To: VantageGroup (E-mail)
Subject: [Vantage] Report Builder and Vantage 6
We are planning on upgrading to Vantage 6 in the near future. I'm converting
all of our custom rb reports. And I'm getting the formatting errors
"WARNING: Format for field XXXXXXXX has to many digits - Format has been
changed"to XXXX whatever. I called this in as the report runs fine once you
click through the formatting errors.
Here's the email response I received:
Cliff,
Currently, there are no plans to change this. The reasons are twofold.
First, Progress will stop supporting Report Builder in the near future.
Second, because this is a limitation of Progress, there is no way a program
fix for Vantage can be written.
As a workaround, I would recommend using Crystal Reports to recreate these
custom reports.
-Matt C.
Matthew C. Cutter
Support Analyst
Epicor Technical Support
mcutter@...
I guess I'd better start learning Crystal in a hurry.....
Cliff Drumeller
Information Technology Manager
Mass Precision Sheetmetal
408 954-0200 ex 217
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=17050071
83:HM/A=1564416/R=0/SIG=11ti81skc/*http://www.netflix.com/Default?mqso=60164
797&partid=3170658>
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egroupmai
l/S=:HM/A=1564416/rand=365654204>
Cliff
database?
Patrick Winter
Cliff,
custom reports.
-Matt C.
Matthew C. Cutter
Support Analyst
mcutter@...
Cliff Drumeller
408 954-0200 ex 217
797&partid=3170658>
