We use printed pick slips to drive our pick operation. Our Bursting
process involves these steps using Fulfillment Workbench:
1. Select order lines that are allocated and off hold. Sometimes
there are over 700 order lines at a time.
2. Select all
3. Release for Picking
4. Print pick slip report
We often have an issue at the point of printing, involving an out of system
memory error. The major issue in this case is that we now have to restart
Epicor, do a query to figure out which order lines to reprint, and manually
select the correct order lines and then use the Reprint function. When
this involves hundreds of order lines, it is time consuming and frustrating.
Has anyone developed another process or customization to get around a break
like this in the process? We have developed a dashboard that allows us to
see the relevant order lines, but it still involves manual selection and
reprint, which can take over an hour.
Thanks for any ideas!
*Tanya Denison* | IT Manager | NRS, Inc.
*2009 S. Main Street, Moscow, ID 83843*
*tdenison@... *|* www.nrsweb.com*
*c: 208.301.0599* | *p: 208.883.7834 Ext 277 *|* f: 208.882.1744*
2. Select all
