If I were a betting man I’d wager they are using regex because the json payload isn’t explicitly typed and instead of looking up each field to see if they are dates they are matching on regex ![]()
REST can send XML schema validated data. REST doesn’t care about the payload. This is a JSON processing issue. As others have pointed out, it is determining type based on how what the data “looks” like.
Excel has the same problem. The solution that Excel uses is to prepend a ’ to the data for force the value to a string. If you want to do something similar, you could add the ’ and test for it in a Data Directive and then remove it.
That’s not a solution, that is a workaround that already has been mentioned.
The solution is that Epicor would look at the schema in the deserialization process.
There is no excuse for the current behaviour.
Agreed. It is a workaround. I know millions of people put up with that very same issue in Excel. Every. Single. Day.
Yes, Epicor should use the schema to determine types. The question is where does this happen? In every business object? How big of a fix would this be?
How long are we willing to wait for Epicor to come up with a better solution?
Excel does not have a schema for the data it is reading. It has to guess.
Epicor has a schema. For every service, every method.
You can examine the schema in the REST help, it is available in JSON and YAML formats.
It clearly shows where the method is expecting a string, where a date or datetime.
My guess there is a single piece of code that does the deserialization for every REST call.
Again. I agree. And trust me, as one who dabbles in AppSec, user input should never be trusted and every input should be validated against EXPECTED values and not just simple schema type checking. I would like value checks and authorization checks too.
This is the best-case scenario. How long do you think it would take Epicor to make the change, regression test it, push it to a preview group, then cloud group, and finally to us on-prem users?
Quite a while.
But it is never going to happen if we don’t report it, or consider it acceptable behaviour.
I can promise you, @Mark_Wonsil is not suggesting anything of the sort. ![]()
Us natural problem solvers will usually try to give you a workaround, AND want it fixed.
It HAS been reported though,right? If not, I would include a link to this thread. We can also ping @pferrington and/or @olga if they haven’t already seen this thread. I’m sure that @timshuwy has been lurking here too.
After doing some testing I can confirm that this bug is relegated to RPC only. OData method work fine and return and keep the data the way it is.
So a trivial work-around for UDXX record is to just use oData endpoint.
Further testing yields this is not a regression of 2023.X it is present as far back as 10.2.700 (only on the RPC calls)
Yes I also checked in 10.2.700 and 2023.1.
Using OData would indeed be the best solution.
Did you check V2 RPC?
Yup V2 RPC same issue
I did as well, same.
I have reported it at Epicor UK support. But they are hesitant to pass it to Dev.
I guess it could speed up the process if any of you can report it to Epicor US.
Consider it done.
Done
I was under the impression that it does not happen when entering data in classic screens.
Of course, classic screens would show modified data, if that was entered in Kinetic UI.
I was under the impression it was, but I just verified it does not, at least not where I am testing.
I will update my bug report accordingly.
Do you have that Case Number, so I can add it?
