Thanks! That did the trick!
Duane
On Behalf Of Michelle de la Vega
Sent: Thursday, October 20, 2005 4:59 PM
Subject: [Vantage] Re: Sales Order Pick List Oddity
Duane
This might help you with you pick list.
Michelle
Sent: Wednesday, November 24, 2004 2:30 PM
To: Michelle de la Vega
Subject: CR Various Crystal forms are missing information
Summary CR Various Crystal forms are missing information
Book Vantage General Information
Page 2353MPS
Page ID 2353MPS
XA610
XA600
XA520
These are standard Crystal forms in Application version 6.00 or
5.20 If
the customer has Crystal Reports 8.5, check the version. It
should be
8.5.2.718 only. Versions prior to the 8.5.2.718 were known to
cause data
to disappear.
The customer can download the latest hot fix; cr85mainwin_en.zip
and the
compile and distribute patch for 8.5: scr8_distr_expert.exe
\MFG6\crystal\crystal85_all_patches.zip on the ftp site,
ftpmpls.epicor.com. Both of these should be applied - first the
cr85mainwin_en.zip and then the scr8_distr_expert.exe., finally
the
Crystal Decisions database and export patch.exe
If you still have problems with Crystal forms dropping data even
with
the appropriate patch as stated above, do a search on the
problem
workstation for: msvcp60.dll and p2bxbse.dll. Check the version
of each
of these files and compare it to the version of the files in the
eMFG\dll folder or \MfgSys60\dll or \mfgsys61\dll folder. If the
versions differ, rename the files on the workstation and copy
the files
from the eMFG\dll folder or \MfgSys60\dll folder.
It may be necessary delete the contents of the local working
directory.
For 6.00, that is the C:\epicor\mfgwk60 folder. For 6.10, that
is the
C:\epicor\mfgwrk61 folder.
If you have questions on this process, call technical support.
ADDITIONAL INFORMATION:
These patches would be applied to the workstations that have
Crystal
only. But the two .DLLs refrenced above may need to be replaced
on any
Windows machine.
This e-mail is for the use of the intended recipient(s) only. If
you
have received this e-mail in error, please notify the sender
immediately
and then delete it. If you are not the intended recipient, you
must not
use, disclose or distribute this e-mail without the author's
prior
permission. We have taken precautions to minimize the risk of
transmitting software viruses, but we advise you to carry out
your own
virus checks on any attachment to this message. We cannot accept
liability for any loss or damage caused by software viruses.
Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You must have already linked your email address to a yahoo id to enable
access. )
(1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database
management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service <http://docs.yahoo.com/info/terms/> .
NOTICE: This communication may contain privileged or other confidential information for the sole use of the designated recipients. If you have received it in error, please advise the sender by reply email and immediately delete the message and any attachments without reviewing, copying or disclosing the contents.
Duane
Duane
Michelle
Page 2353MPS
Page ID 2353MPS
XA610
XA600
XA520
5.20 If
should be
cause data
to disappear.
and the
the
with
problem
of each
the files
directory.
is the
Crystal
on any
Windows machine.
you
immediately
must not
prior
your own
access. )
SPONSORED LINKS
management software
YAHOO! GROUPS LINKS
