Thanks for the heads up. I should note I am still on Vantage 4.0 so have
not run into this issue.
-Todd C.
Sent: Thursday, December 20, 2001 8:17 AM
Subject: RE: [Vantage] Crystal Reports fix
Word of advice, be carefull when replaceing crpe32.dll with other versions.
I am on Vantage 5.00.326 and and am using crystal 8.5 developers addition.
I ran into problems with the crpe32.dll. I had problems with a formula and
tech support advised me to put the 8.5 dll in place of the vantage 7.0 dll.
BIG MISTAKE! Most of the Vantage reports would no longer print. I put
things back as they were and gave up on using my formula.
MArk Dupuis
Ranor Inc.
Sent: Thursday, December 20, 2001 9:03 AM
To: 'vantage@yahoogroups.com'
I moved CRPE32.DLL from my formerly 8.5 PC to the Vantage .DLL folder and
fixed this issue. When I checked the rev level, even after completely (I
thought) removing 8.5 it was different form the Vantage version. I have had
no ill effects but did rename the Vantage version to .DLX before copying
from my PC, just in case I wanted to go back.
-Todd C.
Sent: Wednesday, December 19, 2001 4:36 PM
Subject: Re: [Vantage] Crystal Reports fix
It's because you have CR 8.5. 8.0 would work fine, and I'll bet if you view
the PO form on a workstation without 8.5 it will look fine. 2 options:
Don't print the PO form from your 8.5 workstation. or, have someone get you
the instructions to fix 8.5 for Vantage. Remember, Epicor does not support
CR 8.5 with Vantage... Only 8.0 - although there are numbers of users on CR
8.5 (including myself). Anyone know the proper .dll versions to make CR
8.5 work for Paul?
Troy Funte
Liberty Electronics
-Todd C.
MArk Dupuis
Ranor Inc.
-Todd C.
8.5 work for Paul?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Wednesday, December 19, 2001 12:15 PM
Subject: [Vantage] Crystal Reports fix
I did manage to finally get my Crystal Reports connection up and running!
In order to install 8.5, I had to uninstall previous versions. Last night
I
went over the registry again, and I did see some references to 6.0 and a
7.0
upgrade, which I hadn't seen before. I ripped out 8.5, cleaned the
registry
thoroughly, and now I am running without any problems... sheesh.
BTW, anyone know why Shipping release requirements on the PO FORM show up
for the first item, but not the second?
TIA,
Paul
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
Yahoo! Groups Sponsor
http://rd.yahoo.com/M=210353.1778862.3296836.1261774/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=210353.1778862.3296836.1261774/D=egroupweb/S=17050071
83:HM/A=900179/R=0/* http://www.capcom.com/Yahoo/yahoo.xpml
<http://www.capcom.com/Yahoo/yahoo.xpml> >
http://us.adserver.yahoo.com/l?M=210353.1778862.3296836.1261774/D=egroupmai
<http://us.adserver.yahoo.com/l?M=210353.1778862.3296836.1261774/D=egroupmai
l/S=1705007183:HM/A=900179/rand=819577028>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.1681224.3270152.1261774/D=egroupweb/S=17050071
83:HM/A=879173/R=0/*http://www.fastweb.com/ib/yahoo-76f>
<http://us.adserver.yahoo.com/l?M=178320.1681224.3270152.1261774/D=egroupmai
l/S=1705007183:HM/A=879173/rand=150128998>
