We have an operation with…
Crew Size = 5
Resource = 1 (Sorting)
Labor = Burden
When the Cost Roll is done the Labor and Burdon Costs are multiplied by 5 as expected.
However, when multiple people clock-in to the operation only one of the people has the burden applied.
Are we doing something wrong?
If this is how it is supposed to work, why does it work that way?
I believe it is because you only have 1 resource. Resources generate the burden, not the people (unless the people are resources). If you add more resources to the resource group and the employees log into the separate resources, I think you will get what you are looking for.
I think you may be correct that if we add 4 more resources with $10 of Burden on each the math would come out. But I don’t understand why the Cost Roll doesn’t “see” the same thing. I would think it, also, shouldn’t calculate $50 until we add the 4 additional resources.
