What is the function of the Scrap Qty field in the Time and Expense module ?
After we report the scrap, our cost will has any affect ?
Thank you
Thank you
Any qty you scrap in Time & Expense Entry will be removed from the Job WIP, in Qty only.
Any cost that was incurred for that Qty will count against that Job as a variance if no Reason Code is used or if the Reason Code used is not linked to a GL Control.
