Searching Open Purchase orders
--- In vantage@yahoogroups.com, "fvrm1510" <fvrm1510@...> wrote:
> Our purchaser has a problem that we are seeking an answer to.
> Hopefully , it is something nice and simple.
> "Here is the problem I have with searching for Open Purchase Orders by
> Part Number.
> If I select "search by part number" and "open", the search engine
> brings up "closed" as well as "open' Purchase Orders."
> We had this problem with Vantage 8.0 and don't see a solution in
> 8.03.400 which we are test running right now with intent to go live
> with it 7/1.
> Any help will be appreciated. Thanks,
Thanks for the suggestions... I will pass them on.
Dick
Part Number.
with it 7/1.
Create a quick search.
Of fvrm1510
Sent: Friday, June 27, 2008 8:25 AM
Subject: [Vantage] Searching Open Purchase orders
Part Number.
with it 7/1.
Good Morning,
Has anyone written a BPM that only allows parts entered into a sales order that exist in the parts master? If so can you email me how you did it?
Thanks!
Dale Kalsow | Information Technologies Director
____________________________________________________________________
Determan Brownie, Inc. | 1241 72nd Avenue NE | Minneapolis, MN 55432
( Phone: (763) 502-9689 | ( Fax: (763) 571-1789
* dale.r.kalsow@... | ý http://determan.com/
"Ambition is the path to success. Persistence is the vehicle you arrive in."
Electronic Privacy Notice. This e-mail, and any attachments, contains information that is, or may be, covered by the Electronic Communications Privacy Act, 18 U.S.C. 2510-2521, and is also confidential and proprietary in nature. If you are not the intended recipient, please be advised that you are legally prohibited from retaining, using, copying, distributing, or otherwise disclosing this information in any manner. Instead, please reply to the sender that you have received this communication in error, and then immediately delete it. Thank you in advance for your cooperation.
Create a simple BAQ that shows all basic key info regarding PO records to the depth you require (PO header & line may be sufficient but perhaps you also want users to see release schedule info in the search data).
Create a dashboard from the BAQ and make Part Number, Open status and perhaps a calculated field (call it Net Bal Due - at either the line or release level - qty on order minus qty received to date) user filterable entry fields.
Save the dashboard and enable it to be used as an advanced search.
You can then use it from apps like PO Entry as an advanced search and the user should be able to specify any combo of Open PO status 'Net Bal Due > 0' and/or a specific Part Number.
You could also skip the dashboard step and construct a right click accessible (from, say PO# or Part Number field) Quick Search and achieve the same effect.
Rob Brown
Date: Friday, June 27, 2008, 9:25 AM
Part Number.
with it 7/1.
We are on 8.03.404B and sorting by Purchase Orders with a PO Status of OPEN
only returns open PO's.
If your version is not filtering correctly you can workaround by creating a
BAQ for PO's and connect a PO Quick Search to it.
Ross
fvrm1510
Part Number.
with it 7/1.
Sorry, I meant 'sorting by part numbers'.
Ross Hughes
Sent: Friday, June 27, 2008 9:52 AM
Subject: RE: [Vantage] Searching Open Purchase orders
Ross
Behalf Of
fvrm1510
Part Number.
with it 7/1.
Version 8.03.403D and we only see Open POs returned (The line may be
closed that the part is on, but the Orders are all open).
It may be company or DB specific.
Aaron Hoyt
Vantage Plastics
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>] On
> Behalf Of
> Ross Hughes
> OPEN
> creating a
> Ross
> Behalf Of
> fvrm1510
> Part Number.
> with it 7/1.
