[semi-OT] Win2000 & Exchange 2000
Thanks Steve. I think you just filled in the last of my W2K gaps. I
suspect I will install the new server and move the Exchange database(s) to
Exch-2000 and then remove the old email server making the new one a DC, as
you have. Probably at around US Thanksgiving holiday. Then when I upgrade
to 5.1 at Christmas I will look into upgrading that server to W2K at the
same time (if the 4.0 - 5.0 - 5.1 migration is smooth). This way I could
activate AD and preapre to slowly move all our Win98 PCs to W2K. I will go
very slowly.
-Todd C.
Sent: Wednesday, October 10, 2001 8:49 AM
Subject: RE: [Vantage] Re: [semi-OT] Win2000 & Exchange 2000
Sorry to be so late to respond to the topic; I was out of the office
yesterday.
First of all, the BDC is actually designed to handle login authentication
rather than the PDC. Microsoft designed the software so that BDCs could be
placed all over a large company, even geographically dispersed, and this
would reduce network traffic. It doesn't really affect those of us with
small networks. The purpose of the PDC is to be the central authority that
all BDCs have to synch with.
Todd C. -
I have been running a mixed-mode network for over a year with no problems.
I have 2 W2K Domain Controllers (DC) and my Vantage server is still a BDC on
NT4. Originally, I just converted my PDC to Active Directory (AD) since I
had rolled-out about thirty new W2K Pro workstations and I wanted some of
the cool features that AD Group Policies provides. But then a Microsoft tech
pointed out that my DC had no place to back-up the AD database. The real
problem here is that once a W2KPro system finds a W2K DC it will no longer
log on through an NT4 BDC and I'd be stuck without a back-up. Just
something to think about.
Also, Progress does not support version 9.0 on W2K servers. It does support
version 9.1 on W2K servers, so Vantage version 5 and above should work on
your new server with no problem.
As for Vantage support telling you not to make your Vantage server a PDC,
that's like saying don't plug that radio into the same outlet group as your
television because it might reduce the amount of electricity that your
television gets!! Trust me; there's more than plenty of power to handle the
load. If you have more than 5000 users logging into your network at the
same time THEN it might be a little bit of an issue. Otherwise don't sweat
it. Remember that Microsoft designed this for LARGE networks of 10,000
workstations. I don't think our networks are going to be a problem.
Steve Sanders
Delta Centrifugal Corp
Sent: Tuesday, October 09, 2001 2:43 PM
My BDC is alot faster, I just thought it was beating the PDC to the work.
Patrick
Sent: Tuesday, October 09, 2001 2:32 PM
Subject: [Vantage] Re: [semi-OT] Win2000 & Exchange 2000
The servers are about the same, although the PDC is dual-processor.
If I remember right, from WinNT Server training, the BDC will
authenticate whenever the PDC is busy. If there's a way to tell the
BDC to not authenticate I'm not aware of it. Any ideas?
--- In vantage@y..., "Winter, Patrick" <pjw@s...> wrote:
> Does the BDC do 95% of the login work because it is supose to or is
your BDC
> a lot faster server than the PDC.
> Patrick
> From: brannab@w... [mailto:brannab@w...]
> Sent: Tuesday, October 09, 2001 2:26 PM
> To: vantage@y...
> If I remember, Vantage Tech support recommended not running the
> Vantage server as a BDC. They told me that it would run faster as
a
> member server. I already had mine installed as a BDC when they
told
> me this and I never took the time to change it. You might check
with
> them to see what they recommend. I have noticed that my BDC does
> about 95% of the login and security authentication.
> Bruce Brannan
> Westinghouse EPD
> --- In vantage@y..., Todd Caughey <caugheyt@h...> wrote:
> > OK, NT/Win2000 experts, and especially for those who have
> converted, I need
> > some opinions/advice:
> > I am running NT-SBS 4.5 (w/Exchange 5.5) as our PDC. Other
server
> (BDC) is
> > NT 4.0 running Vantage. I have just received a new server and am
> upgrading
> > to Windows 2000 Server and Exchange 2000. I am still educating
> myself on
> > Active Directory issues but have some questions:
> > 1. Any "gottchas" in the new Win2K server running (or not) Active
> Directory
> > and being the new PDC?
> > 2. Ditto for mixed-mode issues?
> > 3. Should I be switching Vantage server to Win2K at same time?
Is
> this OK
> > for 4.00.12 and Progress 9.0B?
> > 4. Any conversion issues from Exchange 5.5 to Exchange 2000 I
> should know
> > about in advance?
> > 5. Can I bring new server up as a BDC (to get user info) and
> promote it to
> > PDC when I remove old server?
> > I will be hring a consultant to assist but knowing some of this
> before will
> > greatly smooth the process. If you can help me avoid blindly
> walking off a
> > cliff I would really appreciate it.
> > Thanks,
> > -Todd Caughey
> > Harvey Vogel Mfg. Co.
must have
Builder and
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/>
have
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=212180.1660613.3195489.1269402/D=egroupweb/S=17050071
83:HM/A=812074/R=0/*http://www.verisign.com/cgi-bin/go.cgi?a=b15334027000300
0>
<http://us.adserver.yahoo.com/l?M=212180.1660613.3195489.1269402/D=egroupmai
l/S=1705007183:HM/A=812074/rand=838406130>
OK, NT/Win2000 experts, and especially for those who have converted, I need
I am running NT-SBS 4.5 (w/Exchange 5.5) as our PDC. Other server (BDC) is
NT 4.0 running Vantage. I have just received a new server and am upgrading
to Windows 2000 Server and Exchange 2000. I am still educating myself on
1. Any "gottchas" in the new Win2K server running (or not) Active Directory
3. Should I be switching Vantage server to Win2K at same time? Is this OK
4. Any conversion issues from Exchange 5.5 to Exchange 2000 I should know
about in advance?
5. Can I bring new server up as a BDC (to get user info) and promote it to
I will be hring a consultant to assist but knowing some of this before will
greatly smooth the process. If you can help me avoid blindly walking off a
-Todd Caughey
First of all you cannot use Active Directory in an environment that combines
NT4 DC's and W2K "DC's". In other words you will need to have all of your
servers at WIN2K to use Active Directory. Therefore if you want to use
Active Directory you will have to upgrade your Vantage Server at the same
time as you point out that it is a BDC server.
As for the move from NT4 to W2K. You should upgrade your PDC first. MS
recommends Synchronizing your entire domain, then removing your BDC or one
of your BDC's from the network. I mean like stick it in a closet. Upgrade
your PDC to WIN2K. When all is well and users are able to log onto the
network successfully you can begin to upgrade your BDC's. Go to the link
below for a document that discusses the process in detail.
http://www.microsoft.com/windows2000/en/server/help/default.asp?url=/windows
2000/en/server/help/upgrading_a_domain.htm
It is not something you want to undertake without significant planning. You
may also want to do a little research on SBS 4.5, it seems to me that I have
read that there is not an upgrade path for it to WIN2K. That would mean you
are installing WIN2K from scratch, not a bad idea but it will certainly be a
more complicated and more time consuming path to follow.
Good Luck
Todd Hofert
Spartan Graphics, Inc.
(616)887-8243
Sent: Tuesday, October 09, 2001 12:20 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] [semi-OT] Win2000 & Exchange 2000
about in advance?
-Todd Caughey
Thanks Todd. You are correct, there is no direct path from SBS to W2K. I
had an old NT license not being used which I will use on the new server to
"qualify" the upgrade to W2K. So the new server will be a virgin W2K/Exch2K
system and will take over as the primary domain server. The old server is
getting retired as a desktop PC. If there is enough advantage, especially
in making the process smoother, to upgrading the Vantage server to W2K (and
using AD) I may justify that in consultant savings. I just got back from
Barnes & Noble where I bought $130 of W2K and Exch2K books. Guess I won't
have trouble sleeping for the next month or so.
-Todd C.
Sent: Tuesday, October 09, 2001 11:46 AM
Subject: RE: [Vantage] [semi-OT] Win2000 & Exchange 2000
<http://www.microsoft.com/windows2000/en/server/help/default.asp?url=/window
s>
Good Luck
Todd Hofert
(616)887-8243
about in advance?
-Todd Caughey
Vantage server as a BDC. They told me that it would run faster as a
member server. I already had mine installed as a BDC when they told
me this and I never took the time to change it. You might check with
Bruce Brannan
Westinghouse EPD
converted, I need
(BDC) is
upgrading
myself on
Directory
this OK
should know
> about in advance?
promote it to
before will
walking off a
> Thanks,
> -Todd Caughey
Does the BDC do 95% of the login work because it is supose to or is your BDC
Patrick
Bruce Brannan
Westinghouse EPD
converted, I need
(BDC) is
upgrading
myself on
Directory
this OK
should know
> about in advance?
promote it to
before will
walking off a
> Thanks,
> -Todd Caughey
your BDC
> Patrick
> To: vantage@y...
a
told
with
> Bruce Brannan
> Westinghouse EPD
> converted, I need
server
> (BDC) is
> upgrading
> myself on
> Directory
Is
> this OK
> should know
> > about in advance?
> promote it to
> before will
> walking off a
> > Thanks,
> > -Todd Caughey
must have
Builder and
Patrick
your BDC
> Patrick
> To: vantage@y...
a
told
with
> Bruce Brannan
> Westinghouse EPD
> converted, I need
server
> (BDC) is
> upgrading
> myself on
> Directory
Is
> this OK
> should know
> > about in advance?
> promote it to
> before will
> walking off a
> > Thanks,
> > -Todd Caughey
must have
Builder and
yesterday.
Todd C. -
Steve Sanders
Patrick
your BDC
> Patrick
> To: vantage@y...
a
told
with
> Bruce Brannan
> Westinghouse EPD
> converted, I need
server
> (BDC) is
> upgrading
> myself on
> Directory
Is
> this OK
> should know
> > about in advance?
> promote it to
> before will
> walking off a
> > Thanks,
> > -Todd Caughey
must have
Builder and
have
