Server Printing
Hi there, We are experiencing missing Print Outs intermittently while printing using Server Printer. This issue is observed when the Request comes from Hand Held…We have checked the Network Setting, and this is working fine as confirmed by Network Engineer.
We generally get the Task remain in ACTIVE state or ends with ERROR with the following error detail:
“Error creating window handle” and lots of line…
I have checked and performed the following:
1- Checked the Printer Drivers in all App and Task Agents
2- Checked the Network connectivity
Any idea what it could be Or What else could be check ?
Hi, do you have server side printing on desktops? If so, do you have the same issue?
what do you mean by this ?
Hi, you mentioned that you are using handhelds. Just wondering whether you get the same issue if you print the same document using a desktop(wired connection) and server side printing.
Hi, we had issues with server side printing but this was more to with the printer manufacturer drivers. We had to use a specific driver and make changes to the printer setup.
We have tried using Desktop Client, This prints well but we can’t compare the results with Handheld…Since Handheld prints a lot, while from Client, we print few only.
We have Epson E590 (Dot Matrix) Printer, Drivers are Properly installed in all Related Servers.
Was it same happening to you ? I mean Print Miss Out Intermittently ?
Hi, the issue was that even on a desktop if we printing 6 different documents in one batch. It would say print 5 correctly and the sixth would be a copy of the 5th.
