Dragging up an old post here, Chris would you have a link to your SC presentations? I'm in the process of working out how to create a new HDCase through service connect so we can link it to ITSM.
Cheers
Simon Hall
Cheers
Simon Hall
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> .Net is much, much faster, allegedly. Any truth to that?
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
> Sent: Thursday, May 09, 2013 10:48 AM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] Service Connect - 9.05.700+
> Not if you stick with the WSE web services, if you convert them to .net assemblies (either by hand or the converter) you’ll need to shore up a few things… There’s a tremendous difference between how WSE runs and how the .net assemblies work. With the WSE you could be pretty sloppy and get away with a lot, the .net assemblies are a lot less forgiving with regards to data mapping and other things. For the most part it isn’t too bad.
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-4832
> FAX: (715)284-4084
> [cid:1.234354861@... <mailto:1.234354861%40web65412.mail.ac4.yahoo.com> ]<http://www.dsmfg.com/>
> (Click the logo to view our site)<http://www.dsmfg.com/>
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Steven Gotschall
> Sent: Thursday, May 09, 2013 9:29 AM
> Subject: Re: [Vantage] Service Connect - 9.05.700+
> Have you run into any compatibility problems with older SC work flows?
> Steven G.
> From: "Marsch, Chris" <cmarsch@... <mailto:cmarsch%40mdaturbines.com> <mailto:cmarsch%40mdaturbines.com>>
> To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>>
> Sent: Thursday, May 9, 2013 10:01 AM
> Yes this is true, however, this only functions with Epicor 9 and uses the .NET assemblies/business object which is MUCH faster. Also, for those of you that did not know, you can use Service Connect 9.x with Vantage 8 with the web services and still get almost all of the functionality other than direct connection to the business objects from the latest version of Service Connect. You can use database connections where you can connect to any database through ODBC, or whatever and make update, select, and other query statements. There are new features for conversions and sub-workflows as well as new multi-threading and asynchronous processing and many more useful features.
> For those of you attending Epicor Insights in Nashville, I will be presenting on Service Connect and how you can integrate all of your business through Service Connect into Epicor on Tuesday morning.
> Christopher W. Marsch
> IT/Database Administrator
> Mechanical Dynamics & Analysis, Ltd.
> 19E British American Blvd.
> Latham, NY 12110
> (518) 399-3616 x272
> Cell: (518) 795-0200
> From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of mattcald_73
> Sent: Thursday, May 09, 2013 9:37 AM
> To: mailto:vantage%40yahoogroups.com
> Subject: [Vantage] Service Connect - 9.05.700+
> Throwing this out there for those who may not know, because I didn't.
> Starting with Service Connect version 9.05.700, you can communicate directly with the business objects, rather than web services! You import the business objects, just like you would the web service, and boom. From what I was told, much faster communication.
